thecoalman wrote:I don't know what your doing or what the problem is. I suspect you either don't have the latest version of the Windows codecs or something along those lines, if you don't have the latest update for windows media player get it. You may also want to install the windows media encoder.... I think I suggested both before either here or in the other thread.
I ran windows update again, and installed media encoder without any joy.
Anyhow I had no trouble importing the video into VS7 SE and creating a MPEG2 with it... Complete with 3 clips and transitions.
Thanks for trying it. I assume you couldn't get VS to use the .asf file as a template for the project properties?
I did nothing special, I opened up VS dragged the video onto the timeline in three spots, dropped some transitions between them and used the NTSC DVD template. I may have changed the frame type to frame but that wouldn't make a difference anyway in being able to create it...I forget.
I can drag the files to the timeline and play them individually, but if I attempt to perform a high quality preview or save the movie in
any format I get a still image for the duration of each clip (and distorted sound).
I've been examining the codecs installed on my PC using a handy little program called
MMCompView and it's scary how many codecs show up (around 250). The program allows them to be selectively disabled, so out of curiosity I disabled them all and tried opening a .asf file in Windows Media player. It complained that it couldn't find an audio codec, so by trial and error I finally re-enabled just one (Microsoft IMA APCM Codec for MSACM) and tried again expecting it to complain that there wasn't a video codec... but it played the clip instead! So Ive got just one audio codec enabled, but Windows media player plays the audio and the video OK
I've aslo tried using AsfTools to convert/join/repair the files, but it fails to perform any of the operations successfully. I've run out of tools (even Gspot is at a loss to analyse the files). Given the number of Mustek DV x0000 series video cameras that must be out there, surely I can't be the only one facing this brick-wall?
One obvious question is -- do you have the MPEG-4 plugin for your copy of VS7SE? I'm guessing you don't. Do you feel confident that it would solve the problems I face if I were to buy it?
