All,
I'm using MSP8SP1. I have two clips on the timeline A and B. The B clip has a simple motion path applied (a re-size and re-position only for the duration of the fade. Think zooming/re-centering on an oversize BMP image for example or a picture-in-picture effect. B Clip can be image or video.
The problem is that when I crossfade these clips, I get this strange jerkiness. I don't think its a frame ordering (could be wrong) but tried various suggestions to re-set with no luck. When it shifts, it shifts and stays shifted the duration of the crossfade (would a lower/upper frame issue do this? or would it eventually resolve itself?) All video sources are from my same GL2, captured with the same MSP8 capture. The sources for B can be image (BMP or JPG) or video, same issue.
The second (B) clip takes a dramatic shift, typically to the right, sometimes up and down. Sometimes it seems like the aspect ratio of the B clip changes for the duration of the crossfade, then changes back once the crossfade is complete.
This doesn't always show in the preview window - but does sometimes. When the problem exists, it always shows up when creating an output video - its there wheter its an AVI, MPG etc. Not all my crossfades with motion do this, but many/most do.
You can see a less obvious example of the issue here (its my only clip online: http://lenkorproducts.com/video.php it happens about 30s into the clip, after the first fade to black and music starts...)
Anyone experience this issue?
I have had success by saving the clip with the motion applied as an AVI, then replacing the clip with this pre-motioned clip and crossfade. This works.
I have this problem whether my project settings are AVI or MPG. I appreciate any assistance (I know this is all volunteer), and am mostly wondering if anyone else has experienced this. If you need further information, I will be happy to supply. I can make other examples, but don't have them online yet.
Steve
jerky B clip with crossfade on clip with basic motion filter
Desktop: AMD Athlon 1.2GHz, ABIT NF7-S mobo, 1GB, 400GB
Laptop: Dell 9300, 1.7GHz, 1GB, 60GB
OS: Win XP SP2 on both
MSPro: 8+SP1
Video: Canon GL2
MSPro: 8+SP1
Video: Canon GL2
Haven't seen this. I did put on my thinking cap and wondered whether, as it doesn't happen with a re-rendered clip, it may be due to conflict in the temp files and Smart Render. I suggest, the next time you see it happen, you try deleting all your temp files and see whether that does it!
andymchere
Moderators would know better than to post the same message n times in different threads.andymchere wrote:
Maybe I should become a moderator?
Andy
