Upgrading VS8 to VS11
Paranoimia
Post by Paranoimia »
Hi all,
New to the forum, and looking for answers! :D
I've just bought a new machine with Vista, and am looking to upgrade my VS8 to VS11.
From what I've read, in order to use the upgrade, you need to have a qualifying previous version installed. However, I don't have VS8 on this system, since it doesn't work with Vista!
Surely I'm not going to have to buy the full version because of this... am I?
Thanks for any help you can offer!
Not at all. Since at least VS10, all you need is your VS 8 serial number. You buy the upgrade and either get the CD versions or download it (3 separate links, all of which should be downloaded, but only the first two of which contain necessary program files and templates etc. The third is a couple of bonus programs...) On installation, you will be asked to insert the earlier serial number on which the upgrade was based, as well as the new one for VS11, of course. That's it.
Then go to the Ulead website and install, first, a patch dated 6 November 2007 which will fix various problems. And if you have bought VS11 PLUS (which I recommend), then download and install the Hot Pack which will upgrade VS11+ to VS11.5 free of charge...
If you have trouble in your initial install, with specifically an error message relating to the SDK encoder, then there is a more recent patch specifically for that. But ONLY install it, after reading its explanatory notes carefully, if indeed you do have trouble installing VS11. Otherwise, just ignore it completely.
You should also go to the Microsoft DirectX website and download and install the latest update patch for your DirectX 10 which is the version which runs under Vista. The latest patch is dated November 2007 and it fixes things in both DirectX 9.0c (XP) and 10 (Vista). Some people have had difficulties in the VS11 burning module, specifically in seeing previews of menus etc. But the DirectX patch seems to fix that.
Good luck, and welcome to the Forum. Feel free to come back with any questions that might arise! :lol:
Paranoimia
Excellent!
Thank you very much for an extremely helpful reply... I'm off to buy the upgrade now! :D
Paranoimia
Okay, I bought the upgrade and installed it with no problems. However, on the first run after installing both the patch and the Power Pack, the program crashed immediately - but when running for the 2nd time, it was fine.
So far, everything seems to be working fine.
BUT!
There are - obviously - some new features I'm unfamiliar with after the upgrade, but when I try to look at the help file, I just get the error "Cannot find the help file."
Is there anywhere I can download it from?
EDIT: Okay, forget this! I just found the download page in another thread! :oops:
