deonholt wrote:The same time the DVD should have written, I have also chosen to make a copy on my HDD. Funny enough there are no files in the AUDIO_TS folder where as the VIDEO_TS folder has the video files.
How could this have happened? I obviously made a mistake somewhere?
Hi Deon, and sorry to hear you're having some problems!
The lack of files in the AUDIO_TS folder is not caused by a mistake on your part! I believe the folder has to be part of the DVD structure to be in compliance with the DVD standard, that's all.
Since you created DVD folders on your hard drive as well as the DVD, can you play the project from those folders? In your chosen software DVD player, WinDVD or whatever, choose "DVD from folder" as the source, and point it to the VIDEO_TS folder. It should then play the project.
I'm not sure what your audio setup is on your pc - you might have just a small pair of speakers, but even if you don't, you could use headphones. If you've used 5.1 sound, you should be able to get sound output from some of the audio outlets, often times both on the front and rear panels of your pc.
I've not bothered with surround sound myself, since my own audio system is stereo, but if I output a file using 5.1 sound it seems to play the audio OK thru my regular stereo pc speakers. Did you add the music and put it on a particular channel/channels? If so it raises the possibility that your sound system isn't hooked up to those channels. Certainly if playing the DVD on your pc with only stereo speakers, you might not hear the music in that case. I suspect the music on the menu might just be using the normal stereo channels rather than 5.1.
(it's funny though, isn't it - since the advent of surround sound, all Hollywood movies have a helicopter hovering around somewhere!)
Regarding the other issue of not running other programs whilst running VS - that depends on the programs and also on your pc. I would recommend that you disconnect from the internet whilst video editing, and that you disable any scheduled anti-virus scans, and do not have a screen saver enabled. Since Video Studio does not make full use of dual core or quad core cpu's, those cpu's seem to hardly benefit from my usual recommendation, which would be to use a dedicated video editing profile, minimising the number of active Windows services - but in other respects, such a dedicated hardware profile is still a good idea since it helps eliminate conflicts with other programs.
The problems you mention, however, with the video stopping for a second, and seeing a very pixelated image, do not sound like errors caused by interference from other programs. If they are seen when playing the DVD disc, they could indicate a poor quality burn to the DVD, which raises a whole host of other issues! You could search the forum for some recent posts on that subject, but the advice would be first and foremost to find suitable media for your particular DVD burner, and to try burning to the disc at a slower speed for the media you've experienced problems with. If the problems you report are seen when playing the DVD disc, you should be able to compare it with playing the DVD project from the DVD folders you made on your hard drive. If they play OK, it would strongly suggest a problem with the burn quality to the DVD disc.
Some brands of DVD burner, for example Liteon, BenQ, Samsung and Plextor can usefully run disc quality scans which can be helpful in identifying burning problems, and also really useful in finding the best media for your burner.
If you let us know the make and model of your DVD burner, say by looking in Windows Device Manager, I could suggest suitable blank media, but in the absence of that information, I would recommend Sony 16x DVD+R and Verbatim 16x DVD+R, usually giving good results with most burners. Cheap off-brand blank media can be a real lottery!
Good luck!
