It doesn't seem to me that I'm asking too much: any movie is that long!
THANKS a lot! Jean-Pierre
This doesn't make a proper PAL to NTSC version, so it may not work. Either send a PAL version for them play on a pc or use a standards converter programme - expensive - to do it properly.jpm wrote:THANK YOU VERY MUCH!
I already used the "Settings and Options" button next to that "Project Settings" button in order to write a dvd in NTSC format as it had to be sent to the States. Jean-Pierre.
In fact many if not most set top or standalone NTSC DVD players will play PAL discs, so long as they're not commercial discs with regional coding. All my players certainly can.skier-hughes wrote:This doesn't make a proper PAL to NTSC version, so it may not work. Either send a PAL version for them play on a pc or use a standards converter programme - expensive - to do it properly.
