MediaStudio Pro 8.0 (retail version) * Problem with Smart Compositor
Greetings
I keep on receiving error message each time I click on any theme template provided in Smart Compositor. What seems to be the problem ? tried the uninstall-install method still leads to the same problem.
Help/tips/guidance is highly appreciated
[color=green][size=75]Please excuse my english[/size][/color]
Project Properties :
PAL (25 fps)
Microsoft AVI files
24 bits, 720 x 576, 4:3, 25 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- PAL, 48.000 kHz, 16 Bit, Stereo
File Properties :
Microsoft AVI files
Lower Field First
Output format : PAL DVD
Again my problem ~ keep on receiving error message each time I click on any theme template provided in Smart Compositor. (see above image)
* veditor.exe - Application Error
Did I missed anything during the installation or what ?
Appreciate guidance/help on this matter.
zamani wrote:Just found out that some of the files from C:\Program Files\Ulead Systems\Ulead MediaStudio Pro 8.0\video either reads ;
File format mismatch (.swf) or contains no data (.mpg)
Correct me if I’m wrong but to my understanding (by looking at it) , these files are for Smart Compositor
What could cause this problem ? Thanks
Can those play OUTSIDE of MSP? If not, they are obviously corrupt.
Smart Compositer was a nice concept, but, actually you don't really need it to accomplish the same. I have problems with one or two templates not saving the info in the edit. If I exit the Video editor, all is lost.
It _would_ be nice, since a lot of work is already done for you.
I would suggest that your problem may be because these files are not in the right directory. They should be in ...\Ulead Systems\Ulead MediaStudio Pro 8\samples\video.
It is normal that you cannot play SWF files without a Shockwave reader, but the MPG files should play in WMP.
