I read somewhere in this forum that some of the menu templates in MovieFactory don't have highlighted navigation buttons, and I also read the following as a solution to this problem by another member:
" Also as I previously posted some of the templates do not use the highlight button.
So when using some templates the activation is a small part of the thumbnail frame. On a dvd player this small outline can be hard to see.
So that's where I use the customize feature and select "No Frame".
When you play this back in a dvd player the complete thumbnail then becomes highlighted when you select it. Much easier to navigate the dvd. "
I can't find where to select "No Frame". Can you help with this please? I'm using MovieFactory 6.
