Return to menu after dvd is finished playing?
shorthairtwin
I am very new to video editing and VS. I have VS11Plus and have created a few dvd's sucessfully. My next tweak would be making a dvd return to the menu after it is finished playing. Currently it automatically replays without returning to the menu. This sounds like it should be easy but I am not sure what this would be called or how to do it.
shorthairtwin
In the burning module, go to the middle of the three icons in the bottom left of screen -- Project Settings. Down in the bottom of the dialogue box which appears you will see that by default the box 'Auto repeat when disc playback ends' is ticked. Untick it. The box below that now becomes active. And if you click on the arrow, you will see you have the choice to select Back to Menu. As you thought, simple!
Berzelius
- Hard_Drive_Capacity: 2TB
- Corel programs: VS X10 Ultimate; VS X7 Pro; VS 11Plus
May I add my thanks here. I was going to post and ask this very question!Ken Berry wrote:In the burning module, go to the middle of the three icons in the bottom left of screen -- Project Settings. Down in the bottom of the dialogue box which appears you will see that by default the box 'Auto repeat when disc playback ends' is ticked. Untick it. The box below that now becomes active. And if you click on the arrow, you will see you have the choice to select Back to Menu. As you thought, simple!
shorthairtwin
In the burning module, go to the middle of the three icons in the bottom left of screen -- Project Settings. Down in the bottom of the dialogue box which appears you will see that by default the box 'Auto repeat when disc playback ends' is ticked. Untick it. The box below that now becomes active. And if you click on the arrow, you will see you have the choice to select Back to Menu. As you thought, simple! Laughing
Thanks Ken
shorthairtwin
