Choosing output format
HPG
Post by HPG »
My apologies if this has already been covered -- I tried unsuccessfully to find a relevant thread, but I'm a beginner to video editing so I don't really know which keywords are most relevant. I have a Sony HDR-SR8 camcorder that generates .m2ts files, which I gather can be read by MF 6+ with the HD plug-in. If I start on a project in HD format, I understand that I can burn it using a Blu-Ray burner, or in AVCHD format on a standard DVD burner which produce DVDs that can be played on a Blu-Ray player.
But is it possible to burn the same project to DVDs such that they can be played on a standard DVD player? In other words, can MF6+ downgrade the project from HD to standard DVD at the burning stage? Or do I have to start a new project in DVD format and repeat the whole editing process?
MovieFactory can downgrade your HD files to SD, simply select the appropriate output format.
HPG
Post by HPG »
Thanks for your quick reply -- much appreciated.
etech6355
Post by etech6355 »
It depends on what module you are presently in. If your in the AVCHD module you can highlight your edited clip, click on Export -> Customize -> Options and create a dvd mpeg2 compliant video file. Just make sure to make the correct settings related to fielding, framerate & framesize. In the mpg selection, under the Compression Tab you will see NTSC DVD or PAL DVD, select your format then fine tune all the rest of the settings like compression/quality=100%, audio=Dolby Audio etc. Then save the file as a dvd compliant video file to your harddisk.
Start a new project and select dvd, then insert that mpeg2 file you created, create chapters, menus & burn a dvd. Do not edit the video anymore or it will be re-encoded which you don't want to do.
HPG
Post by HPG »
Thanks, too -- very thorough and helpful.
