How can ulead open my disk image file?
daddog
Post by daddog »
Simple question.
How can I (while in Ulead) open a disk image file so I don't have to create the project all over again?
I can find the disk image in the VS 11 folder in the disk image folder, but it is in a RAR format. I can't just double click on it and have Ulead open it.
Thanks in advance. :)
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
The image file is not meant to be opened. You use it for burning your dvd.
So in the burning module you choose burn disc image and navigate to the image and then burn it to dvd.
Post by Trevor Andrew »
You could use Win-Rar to open the compressed/zipped file. (download the trial version)
The iso should contain a TS folder, the Vob files being opened in VS
OR
Burn the Iso to a disc and use VS to import the disc content.
daddog
Post by daddog »
Thanks for the quick replies. :)
How do I get to the "burning module"?
For example when I open VS11 I go to:
Share tab
create disk
Then in the add media window I can't go "next" till I start adding files again. I want to go to the last step where you burn the DVD, but can't until I create it all over again.
Hope that makes sense. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
I do not own VS 11 but using earlier versions:-
The disc image recorder can be found from your Start Menu¡XAll programs¡XUlead Vcd Dvd Image Recorder
Use this to burn a disc of your Iso file ( using a Dvd-Rw will save you a disc.
Then import the disc files to VS
It seems to be a long winded way but if you have lost your project and mpegs then burning the iso seems the next step.
daddog
Post by daddog »
Hi Trevor,
Going that way my only options in VS11 are:
Read me.
Sample Project
VS11
User Manual
I have looked over the manual but it just says how to make a disk image (which I have done) but it does not explain how to then access the disk image and start burning them again. :?
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
VCD/DVD Disc Image Recorder setup file is located in a folder called Ulead Disc Image Recorder, within one of the other download links (uvs11_plus_contentpack_(e).exe) or (uvs11_bonuscd_(e).exe) you received when you purchased the program, or one of the other discs. It is not installed unless you specifically go to the setup file on the disc.
Cheers Ron
I think i can stop looking now
daddog
Post by daddog »
Ugh.
I don't have the disks. It was a download purchase. :?
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Did you not save the download to a disc or the hard drive?
It's a must do operation and a lesson hopefully learnt.
daddog
Post by daddog »
Found it on my external HD. Installing it now with fingers crossed. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog
Post by daddog »
Works great.
Thanks for the help gents. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
skier-hughes wrote:Did you not save the download to a disc or the hard drive?
That¡¦s great
Now save the download files to disc as backup.
