MovieFactory 6+ no audio
PixelShifter
Post by PixelShifter »
I have some .avi files I want to convert to a DVD.
When I import them MovieFactory and check the proferties of the imported files the audio codec (AC3 etc) is listed properly.
That's about it audio-wise. Whatever I try I can't get audio in the resulting video.
The workaround is use a 3rd party tool to convert the .avi to .mpg
Not the ideal way to handle things.....
Is there a way to let MovieFactory handle audio?
A setting? A codec? Or some sort of upgrade pack for MovieFactory?
Welcome to the forums,
Where did the source files (avi) originate, camcorder, internet or some other? What is the properties of the *.avi file? AVI is a wrapper or container, that will hold many types of video CODECs or formats, such as Microsoft AVI, which is uncompressed and takes about 65 gig per hour of video, DV-slightly compressed, yields about 13 gig per hour of video, DivX and Xvid are both highly compressed, MOV, or even mpeg-4, both highly compressed.
Generally with DV the audio used is LPCM or PCM, the others will use MPEG audio Layer 2 or Dolby Digital. If it is Dolby, are you using the Trial (TBYB) version of DMF6? They do not include Dolby due to licensing.
With a video clip on the time-line, right-click and select Media Clip Properties, and post that information back here.
PixelShifter
The source is internet. (it's a recorded TV program)
File
File format: Microsoft AVI files
File size: 195,985 KB
Frame rate 25.000 frames/sec
Duration: 1658.240
Data rate: 117.35 kbps
Video
Compression: DivX 5.1.1 Codec
Atrributes: 24 bits, 528 x 400
Total frames: 41,456 frames
Audio
Compression: MPEG Layer-3
Aributes: 48 kBit/s, 24,000 Hz, Stereo
Total samples: 39,786,272 samples
Program has all updates installed I know of.
Version 6.10.0194.6
Thanks for the feedback
