I just bought a new monitor (important)
Hey everyone PLEASE help. I just bought a new ACER widescreen monitor and now my videos are NOT viewing like my old monitor worked. When i view them there not the full screen anymore. My videos used to be perfect , when i burnt them and viewed them on tv they were full screen, now i burned the same video and the pictures only fill up the middle of the screen, and that is how they view on my computer. What is the best way(aspect ratio) to create a Video File and then finally burn it to disk,,Im doing a simple slide show movie and i want the pics to come out FULL SCREEN , not reg size. I feel like this is a simple tweak here and there but im frustrated. Anything will help
I think you answered your question..
widescreen, which generally is 16:9 aspect ratio.
You probably were using the default 4:3 aspect ratio on your projects. This will need to be changed to 16:9. Open you project, go to File>Project Properties, press the Edit button, go to the General Tab. At the bottom the Display Aspect Ratio, change it to 16:9.
Sounds easy enough, however if your photos were resized/cropped for the 4:3 aspect ratio, there may be some adjusting to be done to the images.
Since you are using a wide-screen monitor you can set VS to use that. You will need to see the start up screen. If you don't already see it, in the Preferences dialog, on the first tab, tick the box beside "Show start up screen". Then close and re-start VS. On the start up screen in the bottom left place a tick in the box beside 16:9. Now the project properties will be set at that ratio.
hellp
All options were set at 16:9 before when i had the smaller monitor, and when i made my disk everything was full screen, now i plug a new monitor in and decided to make the same video again so I can have a copy (because the other one was a gift) and its only letter boxed and i have changed nothing except a new monitor and a new burner. I just dont understand why it would go from full screen on the TV and my VLC media player to pictures with black all around it. I create a MPG File first then put it back on my timeline and create a disk with a menu and it turns out S#$%. :} anyone have a clue
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
OK I'm going to assume the Nvidia Control Panel is the same or similar but if you open yours there shoud be a setting under "Change Flat Panel Scaling and select "use Nvidia Scaling" & Monitor Native Resolution (mine is 1680x1050.
Your monitor setting may be slightly different.
Try that and see how you go
Nope wasnt the video card. When I did that the quality was shot on everything. Since we are not getting anywhere with this, lets try something diffrent. How do you make your pics fit to a full screen w/o losing any quality when played back on your TV. Anything will help, like I said VIDEOS are perfectly fine but pitures are not. I dont want just a simple square pic i want the full screen to filled with pictures, and the wrighting i put into it.. Any other suggestions.......
Try reading through Trevor's article on 16:9 vs 4:3, I've got an idea this might clear up some things, as to why it's not filling the screen..
http://uk.geocities.com/trevor.andrew@b ... 9/16_9.htm
