Still image quality of pan and zoom in v11+ is BAD
pkalen
- motherboard: Asus P5N-E SLI
- processor: Intel Quad Q6600
- ram: 2GB
- Video Card: Asus GS8400
- sound_card: Realtek on motherboard
- Hard_Drive_Capacity: 1TB
The still image quality of "pan and zoom" in verion 11+ is not as good as it was in version 9. It is very disappointing because I would like to move into HD, but I can't sacrifice the still image quality.
I have been a fan of VS since version 6. I create sports highlight videos, and still images are a major part of the content, and every image is "pan and zoomed".
I created a couple of 5 frame mpgs that illustrate the differnce in image quality between version 9 and 11+. I have screencaps from BSPlayer and the mpgs, but I don't know how to make them available to the forum.
The image used is an unaltered jpg from a Canon XTI zoomed to 500 from beginning to end.
I don't expect anyone to have a solution, I just wanted to make it known for others and maybe nudge Corel/Ulead to fix it.
Perry Kalen[/img]
Perry Kalen[/img]
heinz-oz
Some people never modify their images and claim to have good results. My experience, though not with HD or indeed VS, is that it is best to resize the images closer to the target frame size and save these as bmp or other non-compressed format. That works very well for me.
You don't need to get PhotoShop for it either, Ulead's own PhotoImpact works very well for not only that task. It also only costs a fraction of what PS does.
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
pkalen
- ram: 2GB
Thanks for the replies, but the point is, VS 9 did still image pan and zoom very well without resizing or any other preperation, and VS11 doesn't.
I am going to accuse Ulead of dropping the VS 9 pan and zoom and just substituting the lesser video filter pan and zoom. They certainly didn't add keyframe controls to the VS 9 pan and zoom engine Maybe it was cost cutting(royalties). Maybe it was a response for more control(keyframes). But they did not do us a favor.
Could be, I doubt it though. The old 3 stage pan & zoom in VS9 was joke. You had to use what they give you. I don't use the pan & zoom filter on my images or filters. I plan ahead when I'm shooting my video. If I'm going to need to zoom or pan, I do it while filming, so I don't have to rely on software to do it for me.
I really don't find your problem exists in VS11. I've loaded numerous very large images into VS, both resizing and not. In fact I done a quick test using Zoom to 500% and did not see pixelizing by just dropping the images in with their default sizes.
If you're going to use small images, and zoom in, especially to 5x it's size, you will get a degradation. Do that with any program, video or image editor, and you will get the same results.
In Preferences, make sure your Resampling settings are on Best.
Jeff
Dentler's Dog Training, LLC
pkalen
- ram: 2GB
Whoopee, I found the cure.
Preference/Edit - Turn off the Image Anti-flicker Filter.
That makes me happy. I thought I was going to have to search for another editor for HD. Now if HD functions well, that will be great.
I suppose I am stupid, and that little tidbit is in some workflow sticky. Apologies if it is.
heinz-oz
Also make sure to install the patches to VS11+ because they did make the encoding better.
I also suggest to use Frame_Based as your fielding when creating either standard definition or High Definition Slideshows or videos from pictures. That does make a big difference on my system.
You can create a custom template to accomplish this, then assign the template when you render to a file..
