slowing down pan and zoom at end
travsoa
Post by travsoa »
I have recently started using videostudio 11+, I have switched from pinnacle studio.
My only question is, I usually incorporated a feature in my videos that gradually slowed the pan and zoom down at the end of the clip from the full speed to still. From what I have read and tried in videostudio 11+ I can only go from the full speed to stop without the gradual transition (using three keypoints).
Can I start at full speed (pan and zoom) at key point 1 and half way to keypoint 2 start a gradual slow down so that at keypoint 2 the pan and zoom is still and then the still image remains till keypoint 3. This is easy to do in the Pinnacle program, but there is no option to tell videostudio to slow at the end of the pan and zoom.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
It is possible in VS:
You could try 4 key frame points on the same still but the speed of the pan is determined by the duration of the still in the time line.
If you want to play around with varying degree's of speed during the pan and zoom is to have 2-3 of the same still next to each other of different duration. With each successive clip you have to manually punch in the attributes of the last key frame of the previous clip to get a smoother transition between clips.
