I can't find my program cd for Video Studio 9. Is there a link on the Ulead site I can download it from?
Another question if I may ask.
I have some gif animations I want to make into a video which I can do with Windows Movie Maker but I can't keep the transparent background with WMM (at least that I can figure out). Would I be able to with VS9 or any upgraded versions?
Marlene
Can't Find My Program Cd & Info on Transparent Backgroun
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Firstly regarding obtaining another copy of VS9. I do not know of any web site where you could download even a trial version of VS9. I suggest that you either purchase a later version OR look at Ebay - there currently is a listing for VS9 from an someone in Australia. Check http://search.ebay.com.au/search/search ... category0=
Secondly you can render a background transparent with VS9 (and later versions) so long at the background color is a uniform colour and reasonably different than any color in the foreground otherwise when you apply chroma key you might end up with parts of the foreground image being rendered transparent as well as the background (you use the 'similarity' function to adjust now much is rendered transparent).
John a
Or if it is just a copy of the user manual you need Marlene you can download it from here :-
http://www.ulead.com/vs/documents.htm
Also with VideoStudio open either press 'F1' or click on the question mark (top right corner of your screen) to access the programme help files - you may also find the answer in there.
