My software specifications:
- VideoStudio 11 Plus purchased at the online store as an upgrade (I have a VS7 license)
- Installed the patch and the powerpack (upgrading my version to 11.5 Plus)
- OS: Windows XP SP2 (on Core2 T7200 with 2GB Ram)
All worked fine until a week ago when I suddenly got an error message trying to run VS. I don't have a screenshot of the exact message as I did not expected at that time that I would have to find help solving this problem.
I thought: "no problem, I just reinstall VS". So I uninstalled VideoStudio 11.5 Plus by using the uninstaller. Now upon re-installation of VS11, I get the following error message when the setup programming is "Registering Modules" (so near completion of the installation):
When I press "ignore", installation continues and I get similar errors for the following modules:
DibOutput.ax, DibReceive.ax and MCutList.ax
When I check C:\Program Files\Common Files\Ulead Systems\Filters, I can see that all files are present at that location.
The setup finishes (after pressing "ignore" four times) and when I try to run VS afterwards, the following message appears:
I thought that a service might still be running not allowing registering those 4 modules, but I don't see anything that relates to ulead. Furthermore, upon uninstalling, the 4 .ax files are deleted so that indicates to me that they are not in use by any service.
I also tried, as a last resort, to install the hot fix recently published (as it also mentions installation problems, different than mine though), but that did not solve the problem either.
I really don't want to format my hard drive and do a full re-install as this would take me about a full day to set everything properly up once again...
As for why this happened in the first place, my only guess so far is perhaps "CCleaner", although I never had any problems with this program in the past and been using for more than 2 years now. I also use "RegCleaner" to tidy up my registry, but same story, no problems with that in the past.
Anybody got a clue as in how to solving this?
