rendering format for Flash export?
westlight
motherboard: ASRock 970 Extreme3
processor: AMD FX-6100 Six Core Processor 4.20 Ghz
ram: 16 GB
Video Card: AMD Radeon HD 6700 Series
Hard_Drive_Capacity: 8000 gb
Post by westlight »
I'm posting several videos on my website and have decided to do so using Flash. All seems to be going well but I'm wondering if I'm rendering my original project file correctly before importing it to Flash.
This is my process. Open my project into Timeline, then>Share>Create Video File>WMV>wmv Zune 640x480, 30 fps. After that I just import the finished file into Flash. Seems fine but am wondering if I should render to a different format before importing to Flash.
The Project settings were set at Upper Field First to match the original capture. Seems I read a post where the correct setting for online viewing is "Fame-Base". Is this true? I took the third project, saved it under a different name then changed my project settings to Frame-Base before rendering as described above. That video clip is the last of the three at the link below.
The videos can be seen at this link. I am very much in the beginning stages of this page layout so keep that in mind.
http://www.westlight.net/video.html
Thanks for any suggestions!
Not sure if any of this helps but...
Original capture was on a Canon HG10 @ 24 bits, 1440X1080, 16:9, 29.97 fps, Upper Field First, Date Rate (Max 16,000)
westlight
www.westlight.net
GuyL
motherboard: ASUS P6T
processor: I7 920
ram: 6GB
Video Card: ATI 5870
sound_card: Auzentech X-fi Forte 7.1
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG W2753V & HP w2408h
Post by GuyL »
I've settled on saving the file to DV specifications. I've had the flash video encoder cause sync issues in the past using compressed formats.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Post by Black Lab »
If your video will only be seen on a pc (or LCD or plasma tv, for that matter) then you will want to render to frame based. If there is a chance it will be watched on a regular tv then you should render to upper or lower field first, depending upon the source footage.
Awesome videos, by the way. 8)
MrA
Post by MrA »
My vote for the "hometown" competion. After all, he IS at home in his environment.. :wink: I'd probally haved WII'ed on a couple occasions there.
