Hello and thank you for your time, I just bought a Sony Vaio Laptop with a Matshita Blueray player. When i try to play a movie in Windvd (version :
8.0 DXVA B08.385) it says this dics is coded to region a and wont play on this machine. So the st thing i did was go to device manager and check the region under the blueray player, it is set to region 1(us).
So then i went to windvd setup and under region/dvd it is also set to 1 with 4 changes left. Now win i go to the blue ray tab in the setup menu, there is no option selected. and it say i have 5 changes left. But i cant change anything and the options are grayed out. it seems it has been locked with no region. I even tried to start up windvd as a adimitrator, and the same thing, options a grayed out. here is all my info from the info tab ::OS:
Windows VISTA 32
Version:
8.0 DXVA B08.385
Navigation:
Type: BDMV
Region: None
Drive: F:
TV System: Unspecified.
Macrovision Level: 0
CGMS Level: 3
Video:
Hardware:
Vendor: Nvidia
Connection type: DXVA2_ModeMPEG2_IDCT
Downstream renderer: CLSID_DisplayServer
Stream:
Type: Encrypted MPEG2
Bitrate: 15.000 Mbps
Framerate: 29.970 Hz
Resolution: 1920x1080
Aspect ratio: 16x9
Audio:
Info not available
CPU:
Name: Intel(R) Core(TM)2 Duo CPU T7250 @ 2.00GHz
Family:6 Model:15 Stepping:13
Standard Feature: 0xbfebfbff
Hyper-Threading: Not supported, Not enabled
Instruction support:
Intel MMX: Enabled
Intel SSE: Enabled
Intel SSE2: Enabled
Intel SSE3: Enabled
AMD 3DNow!: Not enabled
AMD Enh 3DNow!: Not enabled
AMD 3DNow! Pro: Not enabled
Total Memory:
2.00 GB
ContentID:
3a0KawyU3PZ46C15fQES2IkmvFc=
Computer:
Notebook
Im running windows vista 32 bit.
Any suggestions ?
Region Cant be change
Moderator: lata
- ram: 2 GB
- sound_card: Intel GMA 950
Re: Region Cant be change
Your laptop should be under warranty - go back to the store you bought it from. If you mess about too much you might void that warranty.dankz wrote:Hello and thank you for your time, I just bought a Sony Vaio Laptop with a Matshita Blueray player. When i try to play a movie in Windvd (version :.....
I had the same problem until I downloaded and installed the latest patch from Sony website. Download and install the path from www.sony.com/support . The latest patch will update WinDVD to 8.0 B08.425
