I have done some extensive testing and here are my findings so far.
VS9 Observations!
Pros!
1)what VS8 should have been! seems more stable
2)why bother with DVDWS2 as you have motion menues etc?
3)Chroma key!
4)Works better than Pinnacle Studio 9 plus.
5)Reverse clips!
6) Ripple effect (why call it that?!? why not rubber banding?!?)
7) Digital Pictures seem to be better in this than before ie a lot more clarity and no pulsing on certain images!
9)I have moved my PC onto 08.12.05 no problems with daylight settings
little niggles!
1) Still cant cope with 16:9 within 4:3 ratio. ie it gets squashed if you let video studio automatically do it in PAL DVD 4:3. I set the template 1st and then unchecked non square pix render for AVI. PAL DVD 16:9 works perfect with it as final movie. However on disc it gets squished again for movie I have to uncheck non sq pix rendering for this format! Playback in Power DVD only works when you use pan and scan 1.85:1
2) if you check the normalise audio in final menu of disc creation it crashes out with a message " convert Step got some problems 4525" followed by "unspecified error 0x800411aa (4525)"
3) Chroma key! Better than Pinnacle studio 9 plus! however i had to use the denoise filter to get anything good out of it. but what do you expect for £50 UK. also dont use blue if you have blue eyes! your eyes become seethorugh!
4) Ripple effect (why call it that?!? why not rubber banding?!?) why isnt default that you can have all the time line tagged instead of parts of it? Why parts of it anyway?!?
5) Pictures - you can resize to the PAL safe area! but you dont get a very good picture. same problem was in VS8 but didnt happen in VS7!?! more akin to DVD Pic show 2 quality if you resize it.
6) not many templates for menus. ( i have the ESD version)
7) not many movie maker themes either ( i have the ESD version)
the default setting for PAL DVD 4:3 is 8000 kbps for movie file. The default menu template is 7000 kbps why?!?
