Hilakewud wrote:Thanks ( again ) for the time/trouble to post. I WILL try this method of burning ( once again..failed to burn..stuck halfway!..strange why its got into the habit of doing this..worked fine before )
BUT, what about making a Sound file? and the dvd menu..wouldnt that deteriate?
What do you mean by halfway. Halfway doing what????????? Rendering the video file or burning a disc??????????
This relates to the burner module:-
When you Share Create Disc and Add a video file, there should be No further rendering of the video file.
But you will render the Menu structure, which may take some time depending on which menu¡¦s you have chosen.
To identify if the main video is being rendered:-
VS 9 after pressing Burn you should not see the info window ¡¥This action will take some time¡K¡K¡K
Using VS 10 you will see this info window, but the first ¡¥convert¡¦ should be ¡¥Menu¡¦ (see the blue progress bar)
If you see ¡¥Convert Title¡¦ then you are rendering the main Video.
Some of your settings are incorrect.
Assuming you do Not see the above and the burn is failing then try a burn without menu¡¦s.
Ps create a TS folder or Iso file rather than burning a disc, that will save a disc or two.
