When doing quite a bit of passthrough capturing/editing, I'm finding that I constantly have to go in and change my device control to "None", so that initiating a capture doesn't signal my camcorder to start playing my DV tape. Is there a way to permanently disable this so that it doesn't keep going back to trying to start/stop my DV tape?
Thanks in advance.
Permanently disable "device control"
Since you're having a problem with VS 11, capturing using the pass-through without a tape See this Thread, Iwould say that you will need to set the capture device to none.
Does your camcorder have a setting in it's menu for A/V-DV Out? If so you need to set it to On. I know my camcorder, Sony DCR-TRV 120, to use the Pass-through I must set it to on, and remove the tape. With a tape inserted it over-rides the Pass-through.
