Importing Step Problem: Why do File sizes change?
Undead_Turk
Post by Undead_Turk »
I am trying to burn some video files onto a DVD.
When I import a 697MB avi file, it displays it as a 3.97G file.
And I can't add any more files.
Why does it do this?
heinz-oz
Post by heinz-oz »
Because your avi file is most likely a DiVX or Xvid file and MF converts it to DVD compliant mpeg2. :wink:
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Depends on what sort of avi file it is. There are over 800!!!
If it's a highly compressed file and you select high bitrate settings to make your mpeg2 dvd video then it will fill it if the file lasts about 1 hour.
Undead_Turk
Yeah,
it's a DivX video Compression.
But, How do I Solve this problem?
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
If you want to write a file the same size as the divx one you will need to write a data dvd and buy a dvd player that can play divx files.
Otherwise, you can lower the bitrate you use to write the mpeg2 files, but you will struggle to get 2 hours of decent video on a dvd, particularly as it comes from such a compressed source. you can lower the bitrate down to get 4 hours on a dvd but whether you can watch it is another matter.
This is because mpeg2 dvd video files ahve to be of a set format.
Also, once you've made a dvd video and written it, you cannot add anything to it, whether it contains 500mb or 4gb.
Undead_Turk
So I guess there's nothing I could really do except to just burn this one file onto the DVD.
heinz-oz
Post by heinz-oz »
As Graham said, if you have a player which can play DiVX, just burn the file to DVD as data and play it. You cannot create a DVD from it since DVD standard is not allowing any other compression then mpeg2. Your source file is hence decompressed but the lost data is just that lost and converting it to a less compressed format like mpeg2 is not recovering the data lost in the previous compression to DiVX. The program will invent data to fill the void and expected quality would reflect that creative process.
I usually compare what you are trying to do with someone trying to reconstitute coffee beans from instant coffee. You can press it into shape but it won't be the same.
Undead_Turk
Thanx guys
