Can you fade a Title?
It seems as if you could, but so far, no luck. My titles end abruptly. Isnt there a way you can fade them in or out?
I am using animation ...Moving path, the one ot the top right (vs11 plus). Looking for something to fade but you cant really tell with the previews they give you.
Yes, you can fade your titles. There are several presets under the Fade preset. Then you click on the TT to further customize it to, Fade-in, Fade-out, or Cross Fade. You can also control the Pause Duration, by selecting the User Defined option. Then adjust that by dragging the handles on the Pause-Duration bar, located under the Preview window.
I agree that you can not combine the Fade with this moving path, however you can still do what you want, just involves a different approach.
VS's big brother application, MSP, creates the titles as images, not text like VS. The titles in MSP can be placed on any video track, and all the video filters, and effects, moving paths can be applied to them. Being able to apply video filters and effects to your titles really has its advantages.
- Create your title in VS.
- Select to Save as Image.
- Now use that image as your title.
- Place the title in an overlay track. (It no longer is text, it is an image)
- Use the arrows to have it move onto the stage.
- Also beside the movement arrows are the Fade-in/Fade-out.
- Adjust your pause, using the pause/duration bar.
- Elect to have it fade-out as it is moving off, or just fade-out while positioned on the stage.
I don't know what the default is. I've wished that Ulead/Corel would give us some type of metering for that.
You adjust the duration for the fades by using those small rectangles on either side of the blue bar beneath the preview window. The longer the blue bar the longer the pause, and the shorter or quicker the fade.
So if you have a short bar in the middle the fade-in and fade-out will be longer, and slower.
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
True...but the work around for that is once you made the title to fade in...drag and drop it to the library.... then drag and drop it again right beside the first "in" title on the timeline. Change the second "copy" 's attributes to fade out.rpungin wrote:Can you make a title to both fade in and out? I could only find an animation effect to fade it in OR out but not BOTH.
Adding a third copy in the middle means you can "pause" it for as long as you like.
Yes I know about that method. By the way, adding the middle copy is not necessary. You can control at what point fading begins by changing the length of the blue bar beneath the monitor window.Clevo wrote: True...but the work around for that is once you made the title to fade in...drag and drop it to the library.... then drag and drop it again right beside the first "in" title on the timeline. Change the second "copy" 's attributes to fade out.
But still this is a pain in the butt method if you need to change the title. You have to copy it and again and put back to ensure seamless transition.
I find it weird that VideoStudio does not have a built-in animation setting to fade in and out. It has it for overlays, why not for titles??? Most of the time titles fade in AND out!!
I made a suggestion in "features wanted" thread...
Raphael
http://youtube.com/rpungin2
Clevo
- ram: 4GB
I found that a bit starnge too.rpungin wrote:Yes I know about that method. By the way, adding the middle copy is not necessary. You can control at what point fading begins by changing the length of the blue bar beneath the monitor window.Clevo wrote: True...but the work around for that is once you made the title to fade in...drag and drop it to the library.... then drag and drop it again right beside the first "in" title on the timeline. Change the second "copy" 's attributes to fade out.
I change colour of text in the middle one for that extra bit of effect
Here is a sample title I did using four pics and varying filters from VS..
http://www.veoh.com/videos/v1994001f7h5Jtbj
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Jeff
Dentler's Dog Training, LLC
