Flash animation files won't work anymore
None of my flash animation files are working (they had been). This is the message that I'm getting: The content of these files is unreadable. C:\Program Files\Ulead Systems\Ulead VideoStudio 11\Samples\Video\MotionF31.swf. The most recent thing I have done is download ulead video tutorials and a shockwave flash player. How can get the animation files working again?
Yes Steve is referring to the Ulead program disc. You can also get earlier versions of Adobe Flashplayer HERE.
I had same trouble and repaired with same method...
But what to do if I need more recent Flash Player for other application (for example I store H264 coded video on my web site, and the needed version for reading it in flash player is 9.0.115 !)
Should I install V7 when I use Ulead VideoStudio and re-install V9 when I leave the program ?
Isn't there any clean way to have both installed in separate path ?
Thanks for your advice
tommytucker
Flash issue
My main issue with using the 'old' flash player with VS10+, is that many websites keep asking me to install the latest player to view content. Seems a shame that I can't upgrade to view content on these sites and still use VS10+ Flash functions.
- ram: 2 GB
- sound_card: Intel GMA 950
A method you could use is to find the directory containing your flash files and rename it. Now Install the other version.bblobby50 wrote:I had same trouble and repaired with same method...
C:\WINDOWS\system32\Macromed\Flash
You now have two versions of flash on your hard drive.
The one in the correctly named directory is the one that will be run.
By swapping their names round the other will run.
A quicki method of doing this is to create a batch file using a piece of software called batchrun
http://www.outertech.com/index.php?_charisma_page=index
