No Audio for intro
Zentron
motherboard: ASUSTeK Computer INC. M4A78T-E Rev 1.xx
processor: 2.80 gigahertz AMD Phenom II X3 720
ram: 3.75GB
Video Card: ATI Radeon HD 3300 Graphics
sound_card: ATI 791A
Hard_Drive_Capacity: 1.2TB
No Audio for intro
Post by Zentron »
I just burned 2 DVDs but each time, there has been no audio in the video file I'm using for the intro..... granted they are below 10 seconds, but this shouldn't be a problem! Should it?!
I'm using these settings:
MPEG files
24 bits, 720 x 576, 25 fps
Frame-based
(DVD-PAL), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 224 kbps
What are the properties of the source video file(s) used for the intro's?
Zentron
ram: 3.75GB
Post by Zentron »
AVI format:
Audio
Bit Rate = 1536kbps
Audio sample size = 16 bit
Audio Format = PCM
Video
Frame Rate = 25fps
Video sample size = 24 bit
Video Compression = MC_DVD
And should've said, burned using DVD MovieFactory 10 Plus!
I think you mean VideoStudio 10+
MC-DVD - Main Concept.
Have you installed a separate copy of that codec rather than the codec that is built into VideoStudio which would be listed in the create video stage as PAL DVD.
Zentron
ram: 3.75GB
Post by Zentron »
sjj1805 wrote:I think you mean VideoStudio 10+
Oops, soz, I have them pinned above each other on the Start Menu and got the versions confused!
The DVDs were burned using UMF6+, the video file as put together using VS10... though this is a recent thing! In UMF5 that I was using before I went and upgraded to 6+, I made intros with VS10 and they worked fine when I burned the DVDs. Also, I haven't installed a new audio codec for more than half a year, longer than me having either of the '6 or 10' versions.
Zentron wrote:AVI format:
Audio
Bit Rate = 1536kbps
Audio Format = PCM
Video
Frame Rate = 25fps
Just re-read the above and find this a bit confusing. If your video compression was MC_DVD then surely that created an MPEG2 file not one with an 'avi' extension.
Zentron
ram: 3.75GB
Post by Zentron »
sjj1805 wrote:Just re-read the above and find this a bit confusing. If your video compression was MC_DVD then surely that created an MPEG2 file not one with an 'avi' extension.
Well, this is the output I got Image
Zentron
ram: 3.75GB
Post by Zentron »
Well I tried again though this time to create a MPEG output file, but it crashed about 70% of the way through... bummer!
