Posted: Wed Jan 02, 2008 7:20 am
The time limit in any video format is based on the Total Video_Bit_Rate & the Audio_Bit_Rate.What is my time limit? I can't seem to find that answer anywhere.
There are many bit-rate calculators you can use to perform the calculations.
You can use this formula as a fairly close calculation:
(BitRate in kilobytes * 60) / 8 = KiloBytes per minute.
Playing time for a single sided dvd (4.3 gigs or 4300 megabytes) is
(Size_Of_DVD / MegaBytes_Per_Minute) = Approx playing time.
I use 4200 for the size of a single sided dvd to leave some safe space on the dvd and for menus.
So using your above calculation of 9000 VBR (Variable Bit Rate)
(9000 * 60) / 8 = 62.500 MegaBytes
(4200 / 62.5) = 62 Minutes
That's using Variable Bit Rate in the ulead encoder.
Constant bit Rate is a different calculation (you must add the audio to the video bit rate)
Using the Ulead Encoder if you used 8000kbs at CBR with lpcm audio then the total bit rate would be:
8000 + 1536 = 9536 kbs. Then ((9536*60) / 8 ) = 71.520 MegaBytes Per Minute.
(4200 / 71.520) = 59 Minutes (Note: Dvd's are actually 4.370 Gigs)
It's easier to perform calculations based on Constant Bit Rate.
A Bit-Rate Calculator does all these calculations for you.
Perform a search in the VS forum and you will find some links, there should be a link to a Bit-Rate Calculator in the tutorial section.
