Depends what you mean by "split" - if you mean join two clips together, just hold down the S key or select the scissor tool. The scissor cursor will change to half a scissor if the clips can be joined, or it will change to a bisected circle if it's not possible to join them. There are many reasons why a scissored clip cannot be restored.dabear wrote:1. How do I rejoin a video after I split it
If you mean rejoin audio to its original video then right click the audio or video and select "Unite". If you only have one or other (i.e. you've kept audio or video and deleted the video or audio respectively) then right click the clip you kept and select "Expand". There are many reasons why you might not be able to expand a clip.
Exponential copy: Space out your clips as you want them ON A TRACK OF THEIR OWN. Click the track title (e.g. Video3) to select all the clips. Hold down {Ctrl} and drag the clips to a new position on the same track. They will be copied. Repeat these two steps as often as necessary.2. Duplicate and ejust. I tried to highlight both colors off the track but can't?
painfuly copy pasted like 40 black and white clips.
For example starting off with a single colour clip, the first copy produces a duplicate for a total of two. The second copy results in four, the third copy, eight. By the time you get to the sixth copy you need to delete a bunch of extra clips to get down to your 40.
Another tip: "Stitch trim" works on colour clips too, so if you have adjacent colour clips and you want them to end and start at a different time, just enable stitch trim and drag the clip edge between the two.
Set a preview range using {F3} and {F4} or drag a preview range in the time strip at the top of the timeline.dabear wrote:3. then went to create file but as preview range and I couldn't not click this.
Dunno. Seems to cause less problems when it's switched off. It's implicit in the DV codec anyway, so it makes no difference with my work whether it's on or off.dabear wrote:I noticed you have "perform non-square pixel rendering" unchecked, Mine is checked. What is this?
Toggle the setting if you're having problems with the placement of titles in your final render.
