Then I produced a final DV Type 2 of each of the projects, again all using exactly the same properties, and more particularly 16:9 format. SmartRender was used. I didn't turn off my computer during all this and I must say VS11.5+ performed impeccably the whole time. I was using my XP Pro video editing computer (as per my System button below).
Five of the projects came out without problem. The sixth, and last, seemed to process OK, but when it emerged it was not 16:9 format but 4:3, and the properties, unlike all the others, also did not show it to be 16:9. I repeat: I used exactly the same properties on all projects -- DV Type 2, with VS set in 16:9 mode. I even made two more copies of the project in DV format just to make absolutely sure the properties for the final format said 16:9 (and the second time not using SmartRender). But each time I got a 4:3 result for that one clip. And to repeat again: it was captured from exactly the same mini DV cassette as all the others, at the same time.
Even more curious, when I play it in Power DVD or Nero Showtime, it plays correctly as 16:9 but VS continues to see it as 4:3.
I have also just converted it to widescreen HQ PAL mpeg-2 (8000 kbps, 16:9, LFF, LPCM audio 48000) but it plays as a 4:3 both in VS and now also PowerDVD.
Any clues?
