Hi again, sorry for the delay in replying - University work has had to take priority over the past couple of weeks and I've only just got to getting back into editing this video down again
Ken Berry wrote: However, while I am not sure that switching the Preview Target in File > Preferences to 'DV camcorder' works during capture to cut out the VS preview screen, you might want to try that. It should certainly work, though, for preview after capture.
This is something I did try but it didn't seem to make any difference to anything at all
I'm guessing it was to work, it would just capture and display a preview of the capturing material on the camcorder's screen much like a few of the rival products.
Ken Berry wrote: Does the juddering also occur during capture?
Yes, although it seems to happen at random points in the video which I cannot understand. I know it's nothing to do with the tape or camcorder itself because when I try to capture the same video it rolls straight over that part again just fine
Such as tonight, I captured 2 HD videos just fine and then 29 seconds into the 3rd video capture, it juddered and the preview skipped a few seconds...plus the audio stopped for a few seconds so I had an idea it was a dudd even without playing back
Ken Berry wrote:
For captures from your Sony DCR-HC85E, you could try a small, free and usually trouble free program a number of us here use, called WinDV, which essentially does one thing (capture DV) but does it well. It has a preview window but usually works trouble (and judder) free. If you have a bad preview in that, then the problem is not with VS. Download it from windv.mourek.cz
Thanks for this tip. Unfortunately I should really remove that from my signature, since it's not very reliable after a problem with tapes loading and coming up with errors, although it does act as an emergency camera sometimes - or maybe if a Standard Definition two-camera edit was ever needed
Ken Berry wrote:
Last year, I installed both a new graphics card and a new Firewire capture card on my video computer. Captures before that were as smooth as silk, with the Firewire port being on an analogue TV capture card which I had to replace. The new digital card did not have a Firewire port so I had to install an entire Firewire card. Easy. But the captures were fairly awful to look at (even using WinDV), though oddly enough, after capture, were fine, including in preview. In the end, I moved the Firewire card up a couple of slots on the motherboard to make it first card closest to the processor. And the juddering capture previews stopped.
That's kind of what I can't understand, since I have been able to do a lot of video work with this new HD camera without any problems but now it's causing VideoStudio 10+ to crash or become very unstable some of the time (juddery video
). Is a fresh re-install of VS10+ in order?
Ken Berry wrote:
As for your HD camera, I don't know what to suggest, though some people with different cameras apparently use another freeware program called HD-Split or something like that. Hopefully someone with more HD experience will jump in here.
I will be looking into this program over the next few days to hopefully sort something out - thanks for the tip!!
I think to be honest using an external program for my capturing is the only way to go since unfortunately, even though my computer has gone on a massive crash diet, it's still not stable.
I've currently got a Hardware Profile setup purely for video, but I'm wondering, does the other Hardware Profile (I have 2 running) interfere in any way even though it only loads one on startup?
[b]Computer:[/b] Windows Media Edition, P4 3.0Ghz Processor, 2.5GB RAM, USB 2, Composite, FireWire 1394, SVideo, External HDD 150GB, External HDD 2 - 500GB, Internal HDD 250GB, Ati Radeon X600 256MB Graphics.
[b]Cameras:[/b] Sony HDR-HC1, Sony DCR-HC85E
