DVDMF6+ Crash and Burn when rendering
zforray
motherboard: Dell Optiplex 9020
processor: Core i7
Hard_Drive_Capacity: 5TB
Corel programs: VideoStudio 2018
Post by zforray »
Well, here I am again, with another crash-and-burn when trying to render a DVD.
Don't know how much I can tell you. All patches are on. The 2-videos I am rendering are DivX encoded. Media Clip properties says:
MPEG files
24 bits, 720 x 480, 29.97 fps
Frame-based
(DVD-NTSC), 16:9
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 256 kbps
After the convert/burn process runs for about 55-minutes and then gives me the blue/white application crash box - do you want to send this to M$.
The event log says:
Faulting application dvdmf.exe, version 6.0.0.0, faulting module ulppmgr.dll, version 8.0.0.0, fault address 0x00002fbf.
The burnflow.txt file says:
Burn Flow Report, Date Monday, November 12, 2007, 17:47:43
Start do output action : Pre-check action
AP project GUID : 0143287a-f736-4cac-b7f1-664786fbe686
Core project space : 290455552 byte
Media check ok
DiscLayout clone ok
Project total segment count : 2622143
Project total titla count : 2, Pass title space check : 1
Project total menu page count : 1
DVD Spec. limit check ok
Total title convert step count : 1
Total menu convert step count : 1
Total burn step count : 2
Total step count : 4
Start burn folw action
Tried this on 2-different machines with 4-different files. Must be something in this set of files that is causing some kind of hearburn for DVDMF6+
DVDDoug
Moderator
Post by DVDDoug »
Just to be clear, you are not trying to make a DivX disc... You are trying to convert a DivX file to a regular MPEG-2 DVD, right?
Movie Factory does have trouble editing/converting some DivX, Xvid, MOV, and other highly compressed files. It may depend on the format details or encoding quality... Some people don't have trouble with their particular DivX files.
You might try using a 3rd-party program to convert these files to DVD-compatible MPEG-2. The following programs are FREE!
SVCD 2 DVD MPG (Claims to convert almost anything to DVD format... not just SVCD)
SUPER (A "universal" conversion program.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
