vstudio 11 visual c++ runtime error
davidtwer
Post by davidtwer »
I run trial version of video studio 11. I play scenes (cut off from a video file) in clip mode alright, but when I try to play in project mode, or when I try to create a video file I get "vstudio.dat terminating, visual c++ runtime error".
I have windows XP SP2 and had installed microsoft visual C++ runtime library SP1. Please help Thank you
It seems that a small application included with VS, called uvPL.exe conflicts with MS Visual C++. The uvPL.exe is loaded at windows start up, so try disabling it. To do so, go to Start>Run, and type in msconfig. This will launch the Windows Configuration Utility. Locate the Start up tab, then scroll down until you find uvPL.exe, and uncheck the box beside it, reboot and see if you still get the runtime error..
davidtwer
Post by davidtwer »
thanks, but no, it did not help. I removed uvPL, reboot, ans still get the same error. Any more ideas ?
That little utility is nothing more then sort of a preloader. It helps VS launch faster. If disabling it from the Windows start up in msconfig didn't fix it, then I think you will need to do a clean uninstall/reinstall.
Be advised that Corel (Ulead) apps leave a lot of stuff behind when you do a simple uninstall from the control panel. You will need to clear those so VS does not try to re-use them when you reinstall.
Go HERE for complete instructions on a complete uninstall/reinstall.
davidtwer
Post by davidtwer »
Thanks again. Gee that's some uninstall procedure...
Would it be too much to expect of corel to provide a clean and simple uninstall program ?
Guess I am looking for another video editor...
phil38555615
Did this solve your problem
Post by phil38555615 »
I have the same issue with both Video Studio 11 and 12 now crashing and giving the Visual C++ Runtime Error - it happens as soon as I try to load a video file into my workspace.
