Testing after Power Pack upgrade
mitcs0ke
motherboard: Dell XPS 8300
processor: I7-2600 3.4ghs
ram: 12GB
Video Card: AMD Radeon HD 5670 1GB Ram
sound_card: THX TruStudio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell ST2320L 23 inch
Post by mitcs0ke »
I noticed after the upgrade that VS11+ seems to be running faster on my machine, so I thought I would do a quick project to DVD.
Started Video Studio Editor
Project Properties
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
I grabbed a 12min 19sec 2.47GB video captured in Dv format and threw it into the time line and selected "Not to change the Properties to match video properties" and "No Smartrender"
Went to creat DVD
Motion Menu using Smartscene Menu 05vs_OneS14, No audio
Using Sony DVD+RW disk
Project Settings for the burn
MPEG files
Lower Field First
(DVD-NTSC), 4:3
Audio data rate: 256 kbps
From start to finish Render Menu and movie and DVD format and burn 7min 54sec.
I don't about the rest of you, but I am very happy and pleased so far with
my experience with VS11+
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
I've noticed a performance increase too and I went straight from project to share.
Will do some more testing though. And yes...I'm happy.
dbz2000
processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
ram: 16 GB
Video Card: GTX 1070
sound_card: NVIDIA High Definition Audio Device
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell ST 2310 Analog
Corel programs: VideoStudio 2018_ VideoStudio Paintshop
Post by dbz2000 »
I am just a little confused as to whether you are installing the power pack or the patch. :? I tried to keep up with the thread on this and I thought I had it nailed, but now I am not so sure. Which was it? The patch or the power pack which seems to be two different entities. :?:
Thanks!
DBZ2000
"Instead of trying to add years to your life; try adding life to your years"
Isn't that a bit academic? you need to install both the patch and the upgrade.
dbz2000
ram: 16 GB
Post by dbz2000 »
Probably is a bit academic; but the threads on the topic were a bit confusing. Thanks for clearing this up! :oops:
