Merging Video Clips
Evansv
Merging Video Clips
Post by Evansv »
I have a Hitachi DVD cam and I would like to merge a bunch of clips to 1 main clip. Is that possible I have version 9 of videostudio
THoff
Post by THoff »
Simply insert all of the videos you wish to combine into one UVS project, and then go to Share, and render the project into a new file in the format of your choice.
Evansv
Post by Evansv »
ok so if I do that then there won't be any splits in the video?
I'm sorta new at this.
Thanks again for your help
joosuna
System_Drive: F
processor: intel dual core 3 Ghz
ram: 12Gb
Video Card: nvidia
Hard_Drive_Capacity: 2000
Post by joosuna »
Assuming you have now inserted all your clips into the timeline and they are arranged just as you want them and clipped down to the exact size you want them...now you can insert transitions in between the clips. The transitions can be a simple fade or desolve into the adjacent clip or as fancy as you want to select from the transition menu. Then go to Share Tab and select how you want to save it.
THoff
Post by THoff »
Evansv wrote:ok so if I do that then there won't be any splits in the video?
Correct. You'll wind up with a new output file that contains all the source files in the order they were in.
