Can I create multiple camera output profiles ?
scottb721
Post by scottb721 »
Firstly, great new layout.
I have a Kodak 6440 digital still and a Sony miniDV camcorder.
My Kodak's SD card is not seen by PE8 for some reason so I have the manual path set up so PE can retreive the photos off it -
i.e. L:\ Kodak6440\memorycard\dcim\blahblahblah etc
The Sony's memory stick on the other hand is automatically detected.
I have PE set to create a new date folder inside a particular My Pictures folder. There is a main folder for Kodak pics and another for Sony pics.
Normally I have to browse the folders to find the applicable output folder depending on which camera I'm using.
Is there a way to make PE switch to the correct folder depending on which camera/path is selected as the source location ?
Also but not that important, Why isn't the Kodak SD card seen by PE ?
2log
re: Can I create multiple camera output profiles ?
Post by 2log »
I don't think this is possible. There's no smart command that automatically puts synchronized pictures into subcategories depending on what the camera source is. There is an option to automatically put it on a new folder depending on what date it is though. You can just do that then copy the whole folder later on into whichever camera's subfolder you want it categorized.
scottb721
Post by scottb721 »
Thanks for the suggestion.
I already do that but didn't think of using it like that.
Cheers
