VS9 Video Pan & Zoom Filter
chyao
Post by chyao »
WaxonWaxov wrote:I just reveiwed the VS9 manual (in pdf format downlaoded from ulead.com) and it says nothing about "video pan and zoom"
It only talks about pan and zoom for still images.
So does VS9 allow you to pan and zoom over a VIDEO clip (as opposed to a still image) or not?
The ONLY reson I'm considering upgrading to VS9 is to get VIDEO pan and zoom.
I am sure that the UVS9 has supported pan and zoom over a VIDEO clip.
You can find it in video filter.
BTW, the most key frame point you can add in image pan and zoom is 3.
However, you can add many key frame points in video pan and zoom.
You can check the UI about this function in below address. (Taiwan)
http://photo.pchome.com.tw/photos1.html ... d=1&page=1
THoff
Post by THoff »
Yes, it's definitely in UVS 9, I've used it. Works well unless you zoom in excessively.
For most people the source video is the same as their final output format (720x480 / 720x576), so zooming will always result in pixels being enlarged, whereas with still images, you usually start with a picture that is larger than the output format, allowing full detail to be maintained as you zoom in.
WaxonWaxov
Post by WaxonWaxov »
To quote Katie Kouric: "Thanks so much"
