It's been a while lol & I need sum helps guys uploading.
Mattcharles
Post by Mattcharles »
It's been a while since I used my Ulead VideoStudio 10. I bet there is a new version out lmaoo but I am happy with this one. :)
It gets the job done. Since my computer crashed I now have it back up and running and I want to start doing my music videos again. :)
However, I go to upload the video and I get an error message! I use DVDShrink for my DVD clips to save on my PC. I know I have to change something to .AVI something, I remember that lol but WHAT! What do I change lol. Can someone help? Thanks so much. :)
heinz-oz
Post by heinz-oz »
What do you mean by "Upload"? Capture from a camcorder? Import from a DVD? Capture analog?
How do you connect your devices and what are these?
Mattcharles
When you "Insert a Video" from your PC. I am using clicks from my DVDs that I uploaded from DVDShrink. I used to be able to insert them buy changing something to .avi on the file but I forgot which one lol. There are a bunch of files in the folder where I keep the video.
heinz-oz
Post by heinz-oz »
Are you talking about the VOB files within the Video_TS folder? You rename these to mpg but it might not always work.
Mattcharles
THAT'S IT! MPG! I knew it was something like that! :lol:
Wat can I do to make it work because I have had a problem where it didn't work in the past. :)
You would be better advised first off to try the Insert DVD/DVD-VR command with your DVD in a drive in the computer. That way you can get better fine tuning on exactly what clips you want to import from your DVD.
Mattcharles
Ken Berry wrote:You would be better advised first off to try the Insert DVD/DVD-VR command with your DVD in a drive in the computer. That way you can get better fine tuning on exactly what clips you want to import from your DVD.
Ok I kinda get you, then I don't lol.
If I put the clip on my computer and then upload it, wouldn't that be better? :?: I am confused now. :)
And I was having trouble last night with a clip from a DVD that I uploaded. It was lagging WAY to much.
The correct way to import DVD files is outlined here:
VS : Importing DVD Files
Mattcharles
sjj1805 wrote:The correct way to import DVD files is outlined here:
Thank you very much for the reply! Sorry I took so long to get back here, been REALLY busy.
I keep getting an Unspecified Error when I follow step one. This is the message I am getting
Unspecified Error
Report ID: 0x08000402(16386)
Then after I click Ok for 2 times cause the message above pops up again I get this message below:
No initialization
I do not have a DVD in my DVD Tray because I want to upload from the clicks I copy onto my computer. If someone can help me with this, that would be great! :)
Select "Import DVD folder"
Mattcharles
sjj1805 wrote:Image
That doesn't even come up, all the errors do. :(
Please view Troubleshooting your computer
and look for the part relating to the Windows error log
Mattcharles
sjj1805 wrote:Please view Troubleshooting your computer
I have to pay for that?
Pay for what?
Anyway, I am by now possibly more confused than you seem to be!!! LOL!!! :lol: Are you still trying to copy from a disc? Or have you managed to copy the entire contents of a video DVD to your computer and want to use the video from there?
If it is already on your computer and in a folder called Video_TS, then with Video Studio open, you right click on the Library pane and select 'Insert DVD/DVD-VR'. A little dialogue window comes up, with a big button in the bottom left with 'Import DVD Folder' on it. Press that. You then Browse to the location of the Video_TS folder on your computer and highlight/select 'Video_TS'. A progress bar should appear saying it is 'parsing' the contents of the folder. Then a directory tree should appear, showing all the 'chapters' on the disc. You can preview them in the little preview screen on that page. Then when you have decided which ones you want, you MUST tick the little box to the immediate left of each chapter. Then press OK. The selected chapters should then appear in your Library as individual clips and you can drag them to the timeline for editing.
If that does not work, then the usual fallback with VS10 (though no other version) is to simply use the Insert Video command in Video Studio, and point to the files in the Video_TS folder that have the extension .vob and Video Studio should then insert them into the library pane or the timeline. For Video Studio 10 can see .vob files as video files. And in reality, that is all they are -- mpeg files containing all the video clips on the DVD. VOB is merely the extension used by mpegs when they are burned to a video DVD.
And if that fails, then the final fallback is to open the Video_TS folder on your hard disc, and individually change the letters '.vob' at the end of those files which use that extension, to '.mpg'. Then use 'Insert Video' to import them into the library pane or timeline.
