Capture to external hard drive
Using VS11+ on Windows Home Premimum. When I try to capture video from DV camcorder, and save it to my external hard drive, it refuses to save it there. VS will only let me save it to my hard drive (C).
Any suggestions?
Any suggestions?
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
skier-hughes
- Microsoft MVP
- ram: 4GB
Sorry if you have done this,, but have you changed the Cature Folder to indicate your external hard drive. (from the capture window)kelleen wrote:I'm able to capture and save to the external hard drive with windows media import and another video capture program without any problems.. Maybe a setting somewhere in VS needs to be changed?
or File Preferences--Working Folder
You aren't by any chance doing something different this time, like using your mini DV camera as a passthrough device to capture analogue video from, say, an analogue camera or VCR? If so, VS11 has a bug which will not allow it to capture from analogue source material.
If not, then I noticed that my own VS11+ on Vista Home Premium also captures mini DV badly (though I haven't tried capturing to an external drive). Background applications need to be turned off, otherwise I get a lot of dropped frames.
In any case, I -- and a number of other users here -- tend to use a free, small program called WinDV to capture our DV (never any dropped frames) then open the captured DV in VS to edit it. That works fine too on Vista.
