VideoStudio 11 (Plus) Crashes On Start Up??? Vista
OvrDrive.tk
Post by OvrDrive.tk »
Hey, As it Says In The Title, Im Running Windows Vista Home Premium, And Still When I Open Ulead V.Studio 11 Plus, It Gets To The Splash Screen, And Then Instantly I Get A Windows Error Message Reading That Ulead Has Encountered A Problem. I Havn't The Slightest Idea Of Why? Please Help Me
'Problem signature
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 11.0.0.0
Application Timestamp: 45ebd95b
Fault Module Name: StackHash_7387
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000096
Exception Offset: 08f12a3b
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 2057
Additional Information 1: 7387
Additional Information 2: 5aeda99bb61e25d75e7ae333f7385949
Additional Information 3: 59e2
Additional Information 4: 4c3510a361f023f8b246ff8c448e4e38'
2Dogs
Initial thoughts
Post by 2Dogs »
Hi OvrDrive.tk,
Has VS 11+ ever worked on your pc or has it done this from the outset?
How did you install it? Was it from a downloaded file or do you have a full boxed edition with install discs?
Can you also fill in the "system" information in your profile. Might be helpful to know what kind of hardware you have.
Try looking in the "application" folder of the event viewer - it might give further clues as to what is going wrong.
I would initially guess a corrupted install might be to blame. If you installed VS from a downloaded file, first try re-installing and then re-downloading the file.
If you installed from discs, try running setup again, which should give you an option to repair the install.
good luck!
