Is it worth changeing from 10+ to 11+
JohnWB
Could anyone tell me what are the main changes between 10+ & 11+ and is it worth upgrading for general us using a Sony DCR HC47 DV camcorder.
It would seem looking through the forum posts that 11+ is less reliable than 10+ or is that not the case
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
The short answer from my perspective is no.
I have a standard definition Video cam and VS11+ does nothing that I can't do with 10+. Even if I went to high definition I would still use 10+ because I would only deal with high defintion MPEG2's for editing anyway.
11 in itself has been a bit of a trainwreck for some as you have seen. Hopefully those people will be helped by the upcoming 11.5/patch. I have no plan to upgrade until there is something compelling me to do so and at this point in time there is nothing.
JohnWB
The only reason I upgraded to 11+ was that it was fully compatible with Vista as I just got a new computer running Vista. But as Lance has indicated, otherwise, it is pretty much forgettable. For the basic editing of SD video, no problems, but it doesn't do it any better than VS10+. But to do even simple things that previous versions did, like capture analogue video as DV over a digital mini DV camera as pass through, or (in my case) a Sony Digital 8 camera with analogue 8mm tape playing in it or an analogue capture device which uses DV, forget it.
And that's not even getting into the thorny question of High Def video and the host of other problems that users have found.
We are all hoping beyond hope that the forthcoming release in early November of VS 11.5 will cure a lot of these ills. I for one, based on my previous experience with the product since VS7, am willing to suspend my disbelief until then. But there are just so many and varied problems with VS 11, that I have to tell you right here that I am not at all confident that, after the release of 11.5, there are not still going to be a lot of unhappy campers...
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
From a different perspective:
I've never used any previous versions of VS and I bought VS11+.
I don;t have a back-log of analogue video I need to transfer and I don't have a HD camcorder. Just an good little MiniDV camcorder.
I haven't encountered any problems with VS11+ once I sorted out the initial installation problems. The more I learnt how to use it the more I enjoy VS11+
If what you have is working for you then I don't particularly see the need for you to upgrade.
My only reason for going from 10+ to 11+ was that 10+ consistently crashed on me -- something that had not happened in either VS8 or 9. It would often crash shortly after reopening projects that I had previously worked on, and nothing I tried would solve the problem consistently.
Anyway, VS11+ is at least stable in this regard, which makes it worth it for me even though I don't need any of its "new" features.
Clevo, I see that you are using VS11+ on an XP machine, not Vista. I think a majority of the problems users face (in regard to v11) are attributable to the new Vista OS. Until those bugs are worked out, any software that is made for Vista could have problems.Clevo wrote:From a different perspective:
Jeff
Dentler's Dog Training, LLC
Clevo
- ram: 4GB
That's true too. And I should have pointed that out.Black Lab wrote:Clevo, I see that you are using VS11+ on an XP machine, not Vista. I think a majority of the problems users face (in regard to v11) are attributable to the new Vista OS. Until those bugs are worked out, any software that is made for Vista could have problems.Clevo wrote:From a different perspective:
I'm planning on buying a new system later this year and I'm tossing up between and XPpro64 or Vista. I can't decide which way to go
- ram: 2 GB
- sound_card: Intel GMA 950
I have 4 computers one of which is WinXP/Vista multi boot, one other is XP and the remaining 2 are Vista Home Edition. My preferred operating system remains to be XP. This is due to the vast number of existent programs that either do not work with Vista or have issues. I am sure that in a few years time Vista will have improved but for the time being XP is more reliable.Clevo wrote:I'm planning on buying a new system later this year and I'm tossing up between and XPpro64 or Vista. I can't decide which way to go
mitcs0ke
- motherboard: Dell XPS 8300
- processor: I7-2600 3.4ghs
- ram: 12GB
- Video Card: AMD Radeon HD 5670 1GB Ram
- sound_card: THX TruStudio
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Dell ST2320L 23 inch
Hi John:
I think its what ever you are comfortable with. If VS 10 is doing what you
want it to do, I would stay with it.
I Went from VS 7 on a Pentium 4, XP machine to VS 11 Plus on a Q6600 Quad Core Vista Home Premium machine and it has been like night and day.
There is so much more I can do now and I have not had the Vista problems that some seem to be having.
I have been working on a video for the daughter for halloween with all kinds of things I have learned to do with VS 11, like spooky titles, ghosts,
cloning, and chromakeying.
I love it
I love it
Clevo
- ram: 4GB
I'm inclined to stay with XP and bump it up to the 64bit version on the new system. VS11+ says it's written to take advantage of the 64bit OS. Not sure if that improves performance on not.sjj1805 wrote:I have 4 computers one of which is WinXP/Vista multi boot, one other is XP and the remaining 2 are Vista Home Edition. My preferred operating system remains to be XP. This is due to the vast number of existent programs that either do not work with Vista or have issues. I am sure that in a few years time Vista will have improved but for the time being XP is more reliable.Clevo wrote:I'm planning on buying a new system later this year and I'm tossing up between and XPpro64 or Vista. I can't decide which way to go
Clevo
- ram: 4GB
My understanding is that you can run 32bit programs fine in a 64bit OS but it doesn't take advantage of the ummm...what's the word...bonuses.Ken Berry wrote:One of the problems with the 64 bit system in XP, I had thought, was that there weren't all that many programs written for it. Not sure what the case is now.
I need to double check to see if VS11+ can take advantage of the 64bit of if it's just "compatible"
