Frame size
nosferatu zodd
Frame size
I was wondering if anyone could tell me how i can use the "user defined" option in the Frame size option.
thecoalman
Not for much if you want it to play on a regular DVD player... http://www.videohelp.com/dvd#tech
nosferatu zodd
thecoalman
I'm pretty sure you can't. MF is for disc authoring so it expects a valid VCD,SVCD or DVD standard size which can be adjusted to other standard sizes. I looked in DVD Workshop and there's no way to set a odd resolution so I doubt there's anyway to do it with MF. I don't eve think MF has a export video option does it? That would be required for the video to be of any value since it won't play on anything but a computer.
You can however do this in MSP and probably VS under certain conditions.
You could use MS Media Encoder to convert it to a WMV at odd sizes which is probably your best bet anyway since the video will only be playable on a computer.
Edit: The reason that option is visible is probably because it's a standard dialog box for every Ulead product.
htchien
Ulead DVD MovieFactory 4 has a export video option in the ADD/EDIT MEDIA step.thecoalman wrote:I don't eve think MF has a export video option does it?
H.T.
Ted (H.T.)
thecoalman
Note: the following information provided is what's available using MSP but it should be the same for MF.htchien wrote: Ulead DVD MovieFactory 4 has a export video option in the ADD/EDIT MEDIA step.
H.T.
The "user defined" option becomes available depending on which codec or preset you use. For example if your saving as a mpeg and select the NTSC DVD on the compression tab you only have the choice between different standard NTSC DVD Resolutions (note:DVD video is mpeg-2). If you switch to just MPEG-2 you have a multitude of standard MPEG-2 selections under the presets including the DVD Standards. You still have to select from the drop down menu though.
If your saving as a AVI and select the DV codec you only get a choice of two resolutions (either full frame NTSC or PAL). On the other hand if you switch to a codec such as Divx (and many other AVI codecs) the user defined options become available.
So it real depends on what codec or preset/codec your using. What will be available for that codec depends entirely on what is the standard for that video type.
Again if it isn't a standard NTSC/PAL DVD size you won't be able to play it on standalone DVD player.
