VS 11 sharpening questions???
I use it for my HDV projects... when I choose the minimum amount of the sharpening filter (+1) in stationary (non moving) seens it tends to increase the amount of sharpening at intervals of 2-3 seconds till it becomes unaceeptably sharp????? IS there a way to choose a sharpening amount less the +1? and is there on the web an unsharp mask filter for videostudio 11 plugin to download? I hope it will be added in a future update....
The filters in VS come preloaded with keyframes as examples of how they work. It sounds like you adjusted the beginning keyframe for the minimum sharpness (+1) but the end keyframe is still set at a higher value.
Jeff
Dentler's Dog Training, LLC
Thanks very much... you are right... when I did it right the output looks cool... its a great product.... now all I need is two things:
-Ability to import 24p footage to DVDMF 6+ with HD plugin without reencoding to 1080i 30fps...
-An unsharp mask filter plugin... ulead may make such a plugin available for download as an add on to videostudio 11 plus
If I get those two points solved then I'll consider the package to be superior to packages available for hundreds of dollars more from adobe and Roxio...
Great job Ulead/Corel
