computer locks
kenglos
computer locks
Hi when I use the jog bar in VideoStudo 8 my computer locks up if I don't use it for editing ,and play the video and then pause and cut splitting the video in two then deleting every thing is fine ,what woul be the min needed to run this programe thanks
kenglos
videostudio
Hi I think it is av I put them on the computer via anolog recorder using the three wire yellow red white I don't use the programe much so I don't know much about video thanks for reply Ken
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
kenglos
lancecarr
File Formatlancecarr wrote:Right click one of the video files when you are in VS and select properties. Post the info back here.
Also please fill out your system specifications on the page provided so we can get a "picture" of your set up. You can do it by clicking on "profile" when you are signed in.
Microsoft AVI Files Open DML
File Size 589,822 Kbytes
Frame rate 29,970 Frames/Sec
Duration 600,000 Seconds
Data Rate 969,30 kbps
Video
Compression Sunplus 32 Bit Compressor
Attributes 24 Bits,320*240
Total Frames 17,982 Frames (s)
Audio
Compression PCM
Attributes 44,100 Khz,16 bits stereo
Total samples 26,465,640 samples
