dvd format
You are looking for the best video quality?
The most important factor is bitrate. MPEG-2 is lossy compression. With a higher bitrate, less data is "thrown away" (and you get a bigger file).
Here's a handy online Bitrate Calculator.
Quoting myself
If you use Dolby AC3 audio instead of (uncompressed) LPCM, this will leave you more disc space for higher-bitrate video.
Quoting myself
There is also a "Quality" slider. (I forget where that setting is.) If you set the slider to 100%, the MPEG encoding will take longer, but it will do a better job.DVDdoug wrote:The DVD standard does not set a fixed level of compression -
Higher bitrate = higher quality = bigger file size = lower compression = less playing time.
Lower bitrate = lower quality = smaller file size = higher compression = more playing time.
A good "rule-of-thumb" is 90 minutes per DVD. You can get that with a 6000k bitrate and Dolby AC3 audio. This bitrate is typical of commercal DVDs. (The DVD spec allows video bitrates up to about 9,800k, and up to about 10,000k combined audio & video.)
When you squeeze more than 2 hours on a (single-layer) DVD, you will start to see the video-quality degrade. You'll have to judge for yourself... There are lots of variables including the quality of the source video, the quality of your TV, and how critical you are.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
