resolutions, i/p and frames?
Honnett
Post by Honnett »
Hi.
Does Ulead supports true HD? (1920*1080)
Does Ulead supports both 720 and 1080 in both interlaced and progressive mode?
Which framerates does Ulead supports? 24p, 25p, 50p?
Mikael
etech6355
Post by etech6355 »
Yes, in the Mpeg2 format and all standard framerates, when you select mpeg2 as the encoder there is quite a few choices to select for the framerate. If you select DVD in the encoder you will only get 29.97/25 as a framerate selection. You have to manually select mpeg2 which is very simple to do.
ulead uses the mainconcept encoder both for mpeg & h264 encoding.
