Delete unused video-files
norb
Post by norb »
I`m sure it was answered already, but I can`t find it in search:
I have tons of unused video-files on the hard-drive after finishing my video-project. How do I delete all the files I did not use?
Thanks!
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
in Windows explorer, navigate to where the file is and delete it like you would any other file or folder.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Deleting files with Library Manager
Post by Ken Veal »
It makes things a lot easier if your clips ,files and projects are stored in the Library Manager then they can be deleted in one swoop.To access the L.M either Go Tools ¡VLib Man or select it from the list via the drop down arrow next to where you change the library type.Choose the media type then new-name it,select edit to amend name/description if required.You can then delete the named folders and their contents in one go when you want to.
If you did not use the L.M. a project file will have a .vsp extention.
To delete non consequtive files - Select the 1st file then hold down control as you highlight each file then click delete +shift to delete them all.
To del consequtive files ¡V Select 1st file, +select the last clip which will highlight all inbetween then press del. + shift which will remove all those clips from the library.In V.S. 9 + later confirm that you want the files deleted from the hard drive too.In V>S> 8 + earlier deleting and icon will also delete the original file whether image,audio or a video file. For a tutorial on the L.M. see
http://phpbb.ulead.com.tw/EN/viewtopic. ... 4554#64554
norb
Post by norb »
Sorry, obviously I was not clear: I have a lot of video-clips in the project folder. I used some of them, not all of them. It would be a ton of work to find out the ones I didn`t use and delete them manually.
I know from Adobe Premiere about a function like "Delete unused videos". Then the program automatically deletes all the video-files that were not used for the project and keepy only the ones it needs.
I`m looking for the same function in Video Studio
Clevo
ram: 4GB
Post by Clevo »
OK I know what you mean now. VS doesn;t have this feature and you are comparing it to a professional editing software.
If you set up different project files and keep everything for that project in that folder it makes things a lot easier later on. I intend to keep all mine till I start running out of room then delete old project files in one swoop when the time comes.
In the Wish List section above you'll find something similar to this has been asked for.
norb
Post by norb »
Clevo, thanks for your help!
