AMD or pentium
Rowena
AMD or pentium
Post by Rowena »
Sorry if this is answered elsewhere, I did try searching .... :oops:
My pc has blown up :roll: , probably as it was ready for replacing. I'm therefore searching for a new one and wondered on the best (low end processor) for video editing with ulead 11+. I'm choosing between:
1. Athlon x 2 4400+
2. Pentium Dual Core E2160
Or any other suggestions.
Thanks, Rowena.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Pepsi or Coke?
Fords or GMH?
I prefer Pepsi and Fords and Pentiums!
But it's a choice based on personal subjective bias.
babdi
motherboard: ASRock Extreme 11
processor: Intel 3770K
ram: 32 GB DDR3
Video Card: Asus 660TI 2 GB
sound_card: On board Realtek
Hard_Drive_Capacity: 6.128 TB
Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
Corel programs: Video studio
Post by babdi »
Rowena
I use AMD Athlon 3000+. AMD mother boards and processors are lighter on the purse. AMDs have higher temperature tolerance. I live in India where temperatures go as high 50 deg celcius. AMD does not slowdown or shutoff when temperatures go soaring
AMDs processors are equally good in performance and certain processors outdo Intel
They very stable and also tolerate a bit of user nonsense.I have been using AMD since last 3 years, started with 32 bit and now have 64 bit.
Cheers
Babdi
Rowena
Post by Rowena »
So, I just flip a coin then?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
yes :lol:
Rowena
Post by Rowena »
Cheers Graham! Trouble is I do like a reason for choosing something. Was hoping you were going to say intel were much better than AMD for video editing. :( Or are they both so basic, they're much of a muchness?
Clevo
ram: 4GB
Post by Clevo »
Well people swear that Mac's are better for Video Editing.... :D
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
I had an intel for my first pc, then had an amd for my first pc for video editing, I then had intel and now have a core 2 duo intel for video editing and an amd in my office pc.
It really depends on what range you are buying at, at the top end I'd go for intel, mid to bottom end then really I wouldn't be bothered, it'd be like when I rebuilt my office pc, I bought what was on offer at the time.
Rowena
Post by Rowena »
Fair enough. I have the coin in my hand....
etech6355
Post by etech6355 »
I live in India where temparatures go as high 50 deg celcius.AMD does not slowdown or shutoff when temparatures go soaring
Does AMD have the same internal CPU Temperature protection that Intel Chips have?
babdi
ram: 32 GB DDR3
Post by babdi »
etech6355
Yes AMDs have internal temperature protection. Upper limit is 75 deg c
Clevo
ram: 4GB
Post by Clevo »
babdi wrote:etech6355
Is that protection or the limit before the CPU melts? :)
I have 2 desktop computers
1 has an AMD the other a Pentium dual core.
I have 2 laptops 1 has a celeron the other a pentium dual core.
To be honest they all work perfectly well and you wouldn't know which processor you were working with if you didn't peer into the device manager to find out.
What is important is to keep your computer - whatever it is - in tip top condition with regular housekeeping practices. Take the side panels off every now and again and get the vacuum cleaner out.
Regular defragmantation.
Keep an eye on what items have found their way into your startup menu and the associated registry run sections. Get rid of entries that are not needed so that you dont end up running loads of background processes that you dont really need.
babdi
ram: 32 GB DDR3
Post by babdi »
Clevo
AMD chips are not chocolate coated to melt anyway :D
2Dogs
Intel or AMD
Post by 2Dogs »
Stock performance of the E2160 is roughly the same as an AMD 4400 or 4800, when looking at video encoding.
If you're considering a Tier One pc from the likes of Dell, HP, Gateway, etc, then there really isn't much to choose between the two CPU's performance wise. AMD are pretty competitive with Intel in the "value" sector.
If you're the sort to build your own pc, however, you can take advantadge of the huge overclocking ability of the E2160. It can reportedly be overclocked over 60% using stock cooling, and without increasing the voltage. In that overclocked condition, it's quicker at encoding than even the significantly more expensive AMD 5000.
It used to be the case that overclocking was just for hard-core enthusiasts - but the C2d chips have such good thermals that they can be OC'd without the addition of expensive cooling fans and huge heatsinks. Some people might worry about the longevity of an OC'd cpu - but in my experience, the CPU will become obsolete before you need to worry about it going up in smoke.
I've seen quite a few mentions of Video Studio not being well optimised for AMD dual core cpu's. Whilst I don't know if that's the case, I can say that VS11+ seems to make pretty good use of the 1.8Ghz Core 2 Duo T2400 cpu in my laptop, as the png below shows. It's a Task Manager screenshot made whilst VS11+ was rendering a MiniDV avi file to mpeg-2.
Bear in mind, of course, that there's more to video editing than cpu speed. As Steve suggested, most current pc's are fine for video editing. You can make do with the humblest integrated graphics and only moderate amounts of RAM - though I must admit my experience is with standard definition only.
