Laptop
ulead14user
Laptop
Guys,
Which Laptop would you recommend me to buy for editing High Definition Videos?
I have HDR-HC7 and I would like to buy a Laptop now.
Mac would be too expensive for me...I am thinking of Sony Vaio FZ Series
- Intel Core 2 Duo Processor T7500 (2.2GHz)
- 1 GB DDR-SDRAM (DDR2-667, 512 MBx2)
- 120GB SATA Hard Disk Drive
- SuperMulti DVD±R DL / DVD±RW / DVD-RAM Drive
- LCD 15.4" WXGA (XBRITE-HiColor™)
- NVIDIA® GeForce® 8400M GT
- Microsoft Windows Vista Home Premium
- WLAN 802.11 a/b/g/n w/Integrated Bluetooth®
- Keyboard (Black)
- Standard Battery (BPS8)
Do I need HD RW disc or DVD RW will be okay to write HD videos after editing from VideoStudio?
Please suggest!
- Keyboard (Black)
Please suggest!
ulead14user
Sorry, I forgot to mention that I already have 500GB WD External Hard Drive.Clevo wrote:have never used HD video but it takes up a lot more room I would guess.
120gig HD will not be enough. You might have to consider a much larger HD or an external drive.
Please let me know if Laptop configuration is fine....
Thanks..
In fact, 1 GB of RAM is simply not enough, regardless of what the minimum system requirements might say about VS11. I have a HP dx9200 laptop with a similar Core 2 Duo processor to the one you are contemplating, running VS11+ on Vista Home Premium and I find that the 2 GB of RAM that I currently have is only just sufficient. VS11 is more resource-hungry than its predecessors, and Vista by itself is an incredible resource hog. So get as much RAM as you can afford and that the computer you buy can support -- particularly if you are looking at editing HD.
ulead14user
Thanks Ken..Ken Berry wrote:In fact, 1 GB of RAM is simply not enough, regardless of what the minimum system requirements might say about VS11. I have a HP dx9200 laptop with a similar Core 2 Duo processor to the one you are contemplating, running VS11+ on Vista Home Premium and I find that the 2 GB of RAM that I currently have is only just sufficient. VS11 is more resource-hungry than its predecessors, and Vista by itself is an incredible resource hog. So get as much RAM as you can afford and that the computer you buy can support -- particularly if you are looking at editing HD.
When you say "2 GB of RAM that I currently have is only just sufficient", how do you measure such parameter?
I mean how do we know that the RAM is sufficient or not for a program?
Sorry if I am sounding bit naive....
One more question I have.
Let's say I have a footage recorded in HD format (.m2t) and I use VS11 to edit the footage then would I require High Definition RW Disc (like Blue Ray RW Disc) to write a HD Video or a plain DVD RW can be used?
Thanks....
Yes, I guess what I said was a bit like asking 'how long is a piece of string?'!
But what I meant was that with VS operating on Vista, it is observable that, even with 2 GB of RAM, when capturing, for instance, you need to shut off any background processes and services you don't need to free up resources. And you can see the 'power drain', as you could in previous OS, using Task Manager. Personally, I use WinDV to capture SD video in Vista, then open the DV in VS11+ for editing, and have no problems (as long as the DV source is digital, not analogue ... but that's another story!)
I am afraid I have not yet moved into the HD era, much as I would like to, so I can't really answer your second question. However, it is nonetheless my understand that you can capture and edit in HD format, but then write it to a SD DVD... Hopefully, though, someone with hands-on knowledge like etech, will jump in here...
ulead14user
Ken Berry wrote:Yes, I guess what I said was a bit like asking 'how long is a piece of string?'!But what I meant was that with VS operating on Vista, it is observable that, even with 2 GB of RAM, when capturing, for instance, you need to shut off any background processes and services you don't need to free up resources. And you can see the 'power drain', as you could in previous OS, using Task Manager. Personally, I use WinDV to capture SD video in Vista, then open the DV in VS11+ for editing, and have no problems (as long as the DV source is digital, not analogue ... but that's another story!)
Thanks for your valuable inputs Ken.
Guys,
I would really appreciate if somebody can answer my second question.
"Let's say I have a footage recorded in HD format (.m2t) and I use VS11 to edit the footage then would I require High Definition RW Disc (like Blue Ray RW Disc) to write a HD Video or a plain DVD RW can be used?"
Thanks....
ulead14user
Thanks clevo...Clevo wrote:My understanding, and you could confirm with a google search, that you can record HD video on a standard DVD it's just that you don't fit as much in (duration wise).
Do check though as I am not a HD footage user.
I searched in net and found that Normal DVD can be used to burn HD footage provided the footage has been converted into SD.
However I can use Sony Blue Ray RW+ to write HD footage directly on HD DVD.
Now I have couple of more questions:
I think the work flow is like:
.m2t file (TS Stream) >> mpeg2 (PS Stream) >> Edit using VS11+ >> Burn DVD
Am I right??
If yes then please answer my following questions:
1. mpeg2 is a HD format or SD format?
2. If mpeg2 is HD format then does VS11+ give High Definition output after I edit the footage? Or it just gives Standard Definition Output?
3. Will there be any difference in quality of footage if I record in HD format and covert into SD and burn DVD from the quality of footage I record in SD format and burn DVD?
4. What is the difference between "Proxy HDV Editing" and "Non-Proxy HDV Editing"?
Thanks ....
