Why does PI 12 demand that HDR photos have different shutter speeds? Why won't mulitple images saved with different EV settings during RAW conversion work?
This effectively means I am forced to shoot in bracket mode with aperture priority and a fixed ISO if I want to use the HDR function.
PI 12 and HDR
heinz-oz
heinz-oz
I didn't say there was but tried to explain why, in my humble opinion, the PI HDR function requires AV priority. Not many people are using RAW. I have shot most of my images in jpeg and RAW simultaneously with my Canon EOS 350D but failed thus far in getting a better result from the RAW image. Maybe if I was going to print very large format images that would change. As it stands though I only shoot RAW for special images where I expect to be doing a lot of manipulation of WB etc.
Skeeter
HDR with several photos created from a single RAW will work with a little trick.
You have to bluff PI by using pictures without exif data. In the german version of PI12 you can delete the exif data with 'Bearbeiten --> Duplizieren' . The duplicates have no exif.
Now you can create your HDR/DRI picture as usual.
