UVS 11 movie wizard problem
yanthang
Post by yanthang »
I tried the Ulead Video Studio 11 trial version. When I used movie wizard, it hang after I insert video and click next.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Please read this and report back. We need to know lots of information than what you have given.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
derykp
Post by derykp »
SUBJECT: Please use a subject that describes your exact problem.
Wizard fails on 3rd screen, forced to close VS11+
Describe your problem:
When using the wizard the 3rd screen is unusable ( 2nd Next click) . Only back and cancel buttons and Theme Template menu are not greyed out. All the rest are greyed out.
1] On the Import DVD screen - clip imports fine. All OK here.
2] then use the (start/end) sliders to adjust the clip to a 1 minute clip - all appears OK here.
3] then click next to unusable wizard screen. No pre-view video is shown, the PLAY/FWD/REV buttons don't work ( no video), the Theme Template dropdown does allow selection of Home Movie/Slide Show options. Close box works!. The screen does not allow you to progress so either go back or close are the only options available. Problem is 100% repeatable
Properties of your source files (format, file size, where did you get it?): 1,092GB, 15:46Min clip from a DVD
What devices are involved and their mode of connection?: Internal DVD
Project Settings (important): Using wizard so no project settings configured yet
Output format (file, DVD, VCD, SVCD): Output format setting not yet configured when wizard fails
PAL or NTSC: PAL
Error Codes (if any): none, all options are greyed out
Product Version: e.g. VS10 or VS11+ :VS11+ TBYB
Try this to see if it works.
Instead of using the DVD Movie Wizard select VideoStudio Editor.
Goto the capture tab and select import from DVD
Click here for further instructions
If it now imports then goto the [Share] Tab and select [Create Video]
From here create a PAL DVD or NTSC DVD (dependant upon your region)
If this all goes according to plan, restart VideoStudio and select the Movie Wizard but this time use the saved file from above rather than importing from the DVD.
