VS11 lags and moves VERY slowly!!!!
Sundey
Post by Sundey »
I still have VS7 installed, as well as DVD Factory 3 & 6. (Have not yet uninstalled older versions).
The VS7 worked fine, and I checked Task Manager when VS11 lags and freezes. The resources are fine, and neither CPU or mem usage is high.
I have a P4 3.8GHz CPU, and 4GB of RAM. I also have plenty of hard drive space, and a very good ATI video card. The OS is XP Pro with all updates.
Anyone else having these lockups and lags? Will there be a SP?
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
There are a few reports of lags and usually it's because people are running other applications in the background or, in my case, opened and closed other applications while running VS11+
Do a forum search on associated problems with ATI based cards cause I seem to remember some problems with the ATI cards.
Also do you know which version of Directx you are running>
Or to re-phrase the latter slightly -- have you updated to the very latest revision of DirectX 9.0c if you are using XP? You will find it on the Microsoft DirectX website and it will currently be dated August 2007. (I just checked: you can find it at http://www.microsoft.com/downloads/deta ... laylang=en )
It will still be called DirectX 9.0c which is the version which has now been out for at least the past two or three years, but it contains a number of improvements which seem to be required by VS11 for it to operate properly or smoothly.
Sundey
Post by Sundey »
Yes, I have the latest DirectX. I wll see if there is an update to my vid card, and search the forums for any issues with my card. I have a Radeon X1900, with 512MB on board. Thanks for the direction to look. It lags so bad I cannot even work with it.
Sundey
Post by Sundey »
Wonderful to hear. The only reason I upgraded was because I had to reformat my PC, and I could not find the SN for VS10 that I bought as an upgrade. So, I had to install VS7 (which give me zero issues, but wanted newer version), and then bought the upgrade to VS11. I am very frustrated with the inability to use it due to all the lagging and hanging-up to, say the least.
etech6355
Post by etech6355 »
You must download & install the latest update patches to DirectX 9.0C dated approx June 2007, this is mandatory even if "Dxdiag" displays 9.0c as it's version.
If you registered VS10 with ulead your serial number is listed in their database. You can call them or access your ulead account to obtain your serial number.
When they release the patch for VS11+ it will most likely contain the latest directx drivers, the latest patch to MF6+ which is Patch#2 has this directx update including in it's distribution.
Sundey
Post by Sundey »
etech6355 wrote:You must download & install the latest update patches to DirectX 9.0C dated approx June 2007, this is mandatory even if "Dxdiag" displays 9.0c as it's version.
I tried contacting them, and have not had any luck so far. The email address I registered VS10 with is no longer valid, and cannot get logged in using that email address in order to get the SN.
etech -- as noted in my post above, the current updated DirectX 9.0c is dated August 2007, and no longer June... :lol:
Sundey
Post by Sundey »
Ken Berry wrote:etech -- as noted in my post above, the current updated DirectX 9.0c is dated August 2007, and no longer June... :lol:
Yep, downloaded and installed that and still freezing and lagging. Terrible.
Clevo
ram: 4GB
Post by Clevo »
What are your PC specs.
I've only ever used VS11+ on an oldish PC and I only have lag issues when I use other applications in thw background.
Sundey
Post by Sundey »
--------[ EVEREST Ultimate Edition 2006 (c) 2003-2006 Lavalys, Inc. ]---------------------------------------------------
Version EVEREST v3.00.630
Benchmark Module 2.0.160.0
Homepage http://www.lavalys.com/
Report Type Quick Report
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2007-10-07
Time 22:02
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Computer Type ACPI Multiprocessor PC
OS Service Pack Service Pack 2
Internet Explorer 7.0.5730.11
DirectX 4.09.00.0904 (DirectX 9.0c)
Date / Time 2007-10-07 / 21:58
Motherboard:
CPU Type Intel Pentium 4 570J, 3800 MHz (19 x 200)
Motherboard Name Intel Black Creek D955XBK (3 PCI, 1 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Motherboard Chipset Intel Glenwood i955X
System Memory 3328 MB (DDR2-667 DDR2 SDRAM)
BIOS Type Intel (02/13/07)
Communication Port Communications Port (COM1)
Display:
Video Adapter Radeon X1900 Series Secondary (512 MB)
Video Adapter Radeon X1900 Series (512 MB)
3D Accelerator ATI Radeon X1900 XT/XTX (R580)
Monitor ViewSonic VP2130 Series [21" LCD] (PSD060600136)
Multimedia:
Audio Adapter Creative Audigy 2 ZS (SB0350) Sound Card
Storage:
IDE Controller Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
IDE Controller Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Floppy Drive Floppy disk drive
Disk Drive Maxtor 7L250S0 (250 GB, 7200 RPM, SATA)
Disk Drive Maxtor 6L200M0 (200 GB, 7200 RPM, SATA)
Optical Drive SONY DVD RW DRU-820A (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 198404 MB (46370 MB free)
E: (NTFS) 40954 MB (24000 MB free)
M: (NTFS) 194474 MB (165830 MB free)
Total Size 423.7 GB (230.7 GB free)
Input:
Keyboard Microsoft USB Digital Media Pro Keyboard (IntelliType Pro)
Mouse HID-compliant mouse
Network:
Network Adapter Intel(R) Advanced Network Services Virtual Adapter - Packet Scheduler Miniport (192.168.1.100)
Peripherals:
Printer Adobe PDF
Printer HP Photosmart C7100 series fax
Printer HP1320n
Printer Microsoft Office Document Image Writer
Printer Microsoft XPS Document Writer
Printer Send To OneNote 2007
FireWire Controller Creative Audigy IEEE1394 Firewire Controller (PHY: TI TSB41AB1/2)
FireWire Controller Texas Instruments TSB82AA2 1394B OHCI 1.1+ Compliant Link-Layer Controller (PHY: TI TSB81BA3)
USB1 Controller Intel 82801GB ICH7 - USB Universal Host Controller [A-1]
USB2 Controller Intel 82801GB ICH7 - Enhanced USB2 Controller [A-1]
USB Device USB Composite Device
USB Device USB Human Interface Device
DMI:
DMI BIOS Vendor Intel Corp.
DMI BIOS Version BK95510J.86A.2049.2007.0213.1654
DMI System Manufacturer
DMI System Product
DMI System Version
DMI System Serial Number
DMI System UUID C2E74A22-387011DA-8255000C-6E080217
DMI Motherboard Manufacturer Intel Corporation
DMI Motherboard Product D955XBK
DMI Motherboard Version AAC96732-406
DMI Motherboard Serial Number BQBK54005366
DMI Chassis Manufacturer
DMI Chassis Version
DMI Chassis Serial Number
DMI Chassis Asset Tag
DMI Chassis Type
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Clevo
ram: 4GB
Post by Clevo »
LOL! Ok thanks for that.
You shoud have no problems with that set up.
Do you know what processes you have running in the background? (I don;t need a list if you could tell me how many processes.)
Does VS lag from the very begining when it starts? If not, what are you doing when it starts lagging?
Do you have other programs running in the background still open when you start VS?
Did you have any problems during the installation of VS.
Sundey
Post by Sundey »
[quote="Clevo"]LOL! Ok thanks for that.
Do you know what processes you have running in the background? (I don;t need a list if you could tell me how many processes.) 52 processes.
Does VS lag from the very begining when it starts? If not, what are you doing when it starts lagging? Seems to open OK. Lags terribly when trying to edit a video and/or add audio tracks. I even broke down the video into scenes, so they would be smaller pieces. Not much help.
Do you have other programs running in the background still open when you start VS? Just Symantec AV, corp ed.
Did you have any problems during the installation of VS. - No.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Sundey,
Could you hit Ctrl/Alt/Del and post the typical running processes please.
Whilst Symantec AV will get called to inspect eveything in its search for viruses I can't imagine on a reasonably endowed system it should slow things that much.
What kind of files are you working with? MPEG, DivX, Xvid, DV avi
Post by Black Lab »
I agree with Lance. I think more important than you system specs are your clip and project properties.
Please read the first post at the top of this forum, and answer the requested info.
Well, now it's the second post: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
